SOURCE: ZB 33 and BB 33 BSA
try these guys - they have supplied me with BSA parts a few years ago when I was running a 1942 BSA WM20. My local shop closed down at the beginning of the year. I can't tell you the correct size, am not very familiar with the other engines, but maybe this link will help?
http://www.draganfly.co.uk/shop/pi-166342245.htm?categoryId=513
http://www.draganfly.co.uk/shop/pi-854654882.htm?categoryId=509
if your engine / piston size is not one of these then drop them an email at Draganfly and they should be able to help you.
http://www.umgweb.com/usedguidB.html
B31 1945-60 348cc (71x88mm) OHV single 17hp, 75mph, 80mpg, 325lbs
B33 1945-60 499cc (85x88mm) OHV single 24hp, 85mph, 70mpg, 345lbs
Hope this also helps you. Can't help you with bearings though - sorry mate.
SOURCE: model 238322100 ser cm4768086 type 111
Check the following.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
SOURCE: The ice maker is producing very little ice. How
adjust the tempt of the freezer it needs to be around 0 to 5 deg .. . also ck the food around it as it may be blocking the air flow to ice mker .. mm
SOURCE: My Scotsman undercounter icemaker is
Wow! That the first time I saw one of these! Never even knew they made it under
counter types.Anyway I'll give it a shot,Let's see here It's not producing ice as it should huh? I Googled it for complaints and found this for you,Linda go to
(http://www.retrevo.com) and once you get there type in (Scotsman DCE33)
into site search engine and it'll list service manuals for your model to seek a fix.
It stated how to make maintenence adjustmments ok now good day!
