SOURCE: GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
SOURCE: Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
SOURCE: GE Spectra XL44 Gas Kitchen Range - suddenly only top works
where do I find the pilot light?
SOURCE: The oven does not heat up on my GE Spectra XL44
Might be the bottom element is bad. Not too hard to install a new one.
I am no electrician but if you unplug the stove, remove the bottom element and use an ohm meter attatched to each end, it should show if the element is broken through lack of continuity.
Just an idea from a landlord.
