Ever since my adsl has been installed i have been able to make use of it via the internet cable connection to my computer but has not been able to connect my cellphone to it. i do not know what my password has been the last time.
Unless you have changed it, the wireless password is usually on a sticker on the router. Along with the name of your network.
On your phone, search for your wifi network, click connect, and put in the password exactly as on the router.
Hi Chris,
A few questions for you first.
1) Why would you need your ADSL (connection) password to connect your phone to the Wireless? They should be different.
2) Who is your ISP (Internet Service Provider)?
3) What equipment do you have. The usual set-up is an ADSL Wireless Router (all in one), or an ADSL Modem attached to a Wireless router. Anyway, let me know how yours is set-up.
You can usually change your account details from your ISP web site, there is usually a customer portal for this. Did you set up any account security questions? If so, this should let you change your password. Without this I think you will need to call your ISP to discuss further.
Anyway, feel free to respond and I'l assist if I can...
M.
SOURCE: Attempting to connect new AT&T Tilt phone to router causes internet crash
Well... That's an interesting problem.
Try changing the wireless channel that your router is running on via
the web interface in the router. See what happens when you try to
connect the "Tilt" then.
If that doesn't work, then find out if the Tilt is running on 802.11b
or 802.11g. Disconnect all wireless devices from the router and change
the router's Wireless standard to either B or G ONLY. (Whichever the
phone is.) Connect the Tilt again without any other devices connected
to the router. See if it reboots again.
Those are basics for now. I've never tried connecting a phone to a
router like that before. Otherwise I would definitely contact your
provider and ask them about it. Given that the WRT54G is the most
common consumer-level NAT router on the market, they are sure to be
having issues with it where other customers are concerned.
Unless another wireless device you have is causing the issue. But that
is what you are trying to pinpoint with the above procedures.
Give it a go and see what happens.
Cyryl
SOURCE: Wi-Fi Connectivity
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
SOURCE: A friend has a Thomson TG782t connected via
When you connect the ethernet cable, you are able yo go online. but notwireless . you need to make sure that your computer is connected to thewireless network or not ?
Click Here for more info about wireless connection.
SOURCE: Wi fi on ACER Aspire 4810T connects intermittently
Log into your router and change the channel and see if that helps. Failing that try rebooting the router to factory settings and deleting your connection from the laptop. Then start from scratch again...Hope this helps...Please let me no...
SOURCE: before i used to be able to connect to the
check your internet option and make sureto delete cookies...save your provider,s gprs agin .switch off and restart your phone to use this service
Hi Christiaan Van Niekerk, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
What equipment is connected to ADSL ?
A Router ? make and model number ? check bottom of router for Wi Fi password it might be on it ?
Modem device ? make and model number ?
operating system of computer ?
is there an admin user name and password for router is it on bottom of router ?
go to dos prompt or command prompt on computer
type in ipconfig
press enter
note ip address of default gateway ?
