Lorraine Smith Posted on Jul 14, 2019
Is a multi play cd pd-z82m Comparable with a A-z460 amplifier
  • Patrik Parker Jul 14, 2019
    Hi Lorraine Smith, I want to help you with your question, but I need more information from you. Please Call customer Support Call 1 8O5*465*751O Toll Free 24x7
3 Related Answers
Anonymous
  • 1512 Answers
  • Posted on Jul 07, 2008
SOURCE: Teac PD-1200 Compact Multi Disc Player
Hi
I think that we can get at least one of them going again :)
I suggest
  1. take the lids off both of them.
  2. load up some Cd's and close the drawer and watch what happens.
  3. does the disc begin to spin, is not, do you hear any noise as it tries to read each disc.
  4. can you kick start the CD when it first loads(clockwise direction)
  5. if not of these things happen, can you see if the transport loads the cd up off the tray.
While you are in there, with the front drawer open you should be able to see the laser lens. Use a cotton bud moistened with windex(glass cleaner) gently clean the lens in a circular motion and then also polish it with a dry one to be sure you have left no smears on the lens. Then.... try the unit again and see if the CD reads.
If you don't have any luck this far, please post back to me and we can try some other things. All this and you give me a FixYa... YAY :)
regards
robotek
krb55
Keith Brown
  • 604 Answers
  • Posted on Mar 21, 2011
SOURCE: I have a DC Z-92 amplifier,PD-Z82M CD
first make sure you have phonograph and everything else plugged in where it belongs. or better yet unplug everything and start over. plug in just one source or just use the tuner. make sure that the speaker wires are not shorting out on the back of the amp or at the speakers. if there is a speaker switch on the front (for speaker A or Speaker B) make sure speaker A is pressed in (if you hooked up Speaker A on the back (you may not necessarily have speaker switchs.) make sure when you try the tuner that it is tuned to a good solid station. If after all of the above it still doesn't work, maybe the move caused somthing to come loose inside
gopakumarg43
  • 76851 Answers
  • Posted on Jun 04, 2012
SOURCE: i have a pioneer model pd-m430 6-disc multi-playcd that won't play. it lights up when you turn it on but no sound. it some times channel through the discs but does not play
It sounds that the opticla pickup unit has the fault. Clean it and check. If this do not help you, replace it.
For more details, just type in the site name "Electro-help" to your search engines' search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts. You can get all details.
You can locate it either at the bottom part of first search page, or at the top of second page. Detailed descriptions are there to help you.
Sometimes, clicking on advertisements by the side and bottom of each post might help you to get details about the availability of spare parts; price etc:-
Pioneer SX-P720 circuit diagramn and wiring diagram wanted please i really need it for pioneer GR-Z460
What do you mean by the leads are "flat type" on the Marantz? Are you referring to the speaker wire output terminals? If so, the graphic equalizer should be connected to the pre-amp input of the amplifier, not the speaker level outputs.
I have a DC Z-92 amplifier,PD-Z82M CD player,PLZ-92 Phono deckand F-Z92l tuner, was working fine till moved house,lost manual on how to connect it back up again,can hear very faint sound from speakers but...
1helpful
2answers
IT is Pioneer PD-M430 6-Disk CD changer
turn the cd, the silver side must be look down
 Grubhead
Grubhead
SmartAviator
SmartAviator
