If you can take it out and put it in, and it is a battery. Then yes your fitbit battery can be changed. Make sure you replace with another battery though. A nickle or a dime will also do the trick but keep in mind if you use a nickle or a dime in place of the battery you must carry a pencil and a note pad to write down your steps count as needed. Either of the two are equally popular choices. Glad I could help, thats why Im here!
The quick answer is that the watch was designed so the answer would be no.
The longer answer is that all things are possible but it is not easy.
The best answer is that you can buy a refurbished watch with "some" warranty, at least in the USA from a third party.
https://www.youtube.com/watch?v=DYwEM7W19dg
