Boating Logo
John Hollingsworth Posted on Jul 13, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Yamaha 90 outboard 2006. The power tilt does not work. What is the problem?
Gordon Richard MacLean
Level 2:
Champion:
  • Expert 253 Answers
  • Posted on Jul 14, 2019
Expert
Level 2:
Champion:
Answers
253
Questions
Helped
77368
Points
481
Good Morning John ,
Is it completely dead or Doo you hear anything when trying to trim?
Try the simple things. First ,check the fuse in the engine wiring harness, there are two fuse holders one is chsarge power fuse the other is trim fuse.
Replace if blown with same size fuse
There may even be spare fuses in the wiring harness in a clear plastic holder.
Hope this helps
Regards Gordy
Dariusz Zalewski
Level 3:
  • Master 1,095 Answers
  • Posted on Jul 13, 2019
Dariusz Zalewski
Master
Level 3:
Answers
1095
Questions
0
Helped
297017
Points
3055
Either fuse, switch or pump itself. See your friendly mechanic
From where can i buy a 1989 Yamaha 90 Etlf Outboard Service Manual?
This manual has been prepared by the Yamaha Motor Company primarily for use by Yamaha dealers and their trained mechanics when performing maintenance procedures and repairs to Yamaha equipment. It has been written to suit the needs of persons who have a basic understanding of the mechanical and electrical concepts and procedures inherent in the work, for without such knowledge attempted repairs or service to the equipment could render it unsafe or unfit for use.
You can download a copy of the manual from:
https://www.heydownloads.com/product/1989-yamaha-90-etlf-outboard-service-repair-maintenance-manual-factory-service-manual-pdf-download/
Will low fluid level cause power trim/ tilt go not hold position
Low fluid level will cause it to fail to actuate and not go up or down, can also let it not hold position as well. Filling to proper leevel with specified lubricant is recommended. If you allow the level to go too low, the pump will pull air and could burn out.
How do I replace the motor on a yamaha power tilt and trim 1995
loosen engine mounting bolts and steering tube , trim engine up by releasing the valve on the side and tie up so not tocome down ! remove pin on the ram then remove all bolts and wires and should come out !
I need the torque specs for the big ends, crankcase and cyl. head of yamaha 90 outboard 1996
This will be a good source of info for Yamaha outboards: http://www.marineengine.com/boat-forum/forumdisplay.php?37-Yamaha-Outboard-Forum
Yamaha Outboard Forum
Jan 25, 2014 • Motorcycles
Yamaha outboard 8 horse power tilt removel trouble
Trouble removing it from the transom? Is it C clamped into the transom? Or a bracket built of the transom?
Top Yamaha Boating Experts
neil
Stan Ford
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
