SOURCE: Power door locks
You will need two power door lock actuators. They are pretty easy to install and would be wired to the new alarm system.
From what I see, decent DEI ones go for about 50 a pop. Atleast, in my area retail. If its something you are interested in, as of Aug 18th I still have two BRAND NEW in box that I never used on a client's old honda DX. Both the high powered versions.
Hit me up if interested sometime ddowling06 at g mail .com
SOURCE: Viper 5901, Ford 2008 6.4/ When I use the trucks door keypad
If you use the viper remote to arm the alarm, you MUST use the viper remote to disarm the alrm prior to opening the door. The only REAL solution is to add the keyless entry feature to the viper system, and quit using hte factory remote all together.
SOURCE: just baught a truck with
Can be somewhat complicated to explain, particularly without knowing the make, model & year of the truck and which bypass was used to integrate into the factory systems. But here's one thing it might be. The Viper system is aftermarket obviously, when the alarm is triggered the siren with start to sound, and sometimes the horn will honk as well (depending on the vehicle and the bypass). If the siren isn't blaring that means the Viper system was disarmed when you unlocked the doors but not your factory security....or another way to word it is if only the horn is honking and no siren then you're factory alarm system isn't being controlled by the viper remote the way it should be. The factory disarm wire needs to be connected. It's a light green wire with a black stripe in a red connector in the Viper alarm brain. For anything more specific I'd need some more info on the vehicle. You can email me at [email protected] if you'd like.
SOURCE: wiring diagram for ce 0890 remote start
On some remote starters, there is print on the back of the remote starter itself. It is hard to see with it being black raised text on a black box. If not there, sorry DEI Viper is pretty protective on their installation manuals.
