I have tried to replace the PuriClean II filter in my fridge but it leaks. If I put the old one back in which to my eye is identical it doesn't ! Am I missing something or is this a common problem ?
SOURCE: Amana fridge water filter squealing
I would suggest that you put the new water filter back in and try dispensing water for about ten minutes. If there is still a high pitched noise then you could try bleeding the water line at different points along the water circuit (with control over the incoming supply). The fact that you are forcing water through the tank should normally resolve any air locks. The water filter could also be bled of air. Hope this is of some help.
SOURCE: Fridge leak by water filter Fridgidaire
Hello, sounds like the o-ring for the housing that the filter goes into was damaged. You can get a replacement o-ring from your locale appliance parts wholesaler/dealer - OR if you have a really good locale "Hardware" store - remove the o-ring from the male part of the housing that stays in your fridge (pinch it between you fingers around the diameter and you should be able to get it out). They should be able to match it for you - If I recall it is a standard size. If you cannot find one right away you may be able to get it to stop leaking temporarily by getting some Sillicone O-Ring GREASE and applying it to the o-ring. This may stop the leak but I would still replace the oring when you can. Good Luck Dr. Know
SOURCE: water leaks when filter is connected
Does it leak from the back or the front of the appliance ??
