SOURCE: can't remove under counter microwave.
I think there are only three very long bolts that can be used to attach this microwave to the cabinet floor or shelf. Grease, paint, varnish all can make the case stick to the cabinet. You might try running a putty knife or scraper around all the exposed edges keeping the top bolts in place so it will not fall down.
SOURCE: white 1418 sewing machine
If you have taken the hook out that is the half moon shape first of all make sure the needle is at the top of the machine, hook in, gate up and that is all there is to it.
SOURCE: I need a motor pulley
Here are three sites that are selling the pulley motor for the 77 series
http://www.premiersewing.com/white-77-family-rotary-1-4-diameter
hope this helps... lew
SOURCE: my washer won't spin, I
Hi .Just read your posting.I need to know the make and model of your machine and also if it is a front or top loader.If you can supply this information I am sure I can help you.Hear from you soon.
SOURCE: does the white mighty mender w100 suppose to pull the material through the machine while sewing?
yes, the feed dogs are what moves the fabric thru the machine
