SOURCE: Toshiba 32d46 single horizontal line in center of tube
Hi. Check the frame output IC for dry solder joints.
SOURCE: Understanding Outlet Circuit Test Results
open ground=ground wire (green) is not connected to the circuit box ground or to the earth ground.
(there should have steel rod place in the ground by the local electric company, and gtound wire is connected to that rod).
Open Neutral= same as open ground. unless you are testing 240V, which have 2 hot (110v) and a neutral (0V).
Open Hot= open 110v line (black)
hot/ground reversed= if you understand the above, then this sould be self explaintory.
same a hot/neu. reverse.
if you don't understand how electric wiring works, My suggestion is to stay out.
SOURCE: what does open neutral on my gb circuit tester
An open neutral means that neutral, or common wire is not connected somewhere. If for example you test a outlet in a room, and the tester shows that you have an open neutral, Then somewhere along the circuit the neutral is not connected properly. In rooms most outlets are connected in series to each other, so if you have an open neutral in one outlet, it can affect all the other outlets too.
Hot/ground reversed means that the hot wire and the common wire are installed in the wrong order.on the outlet,you have a hot side (black wire)and a common side(white wire)and the hot wire is installed on the common side instead of the hot side and the common is installed on the hot side.This show up on the tester this way because the common and ground tie into the same bar in the panel.
Fix the open neutral first as this can show incorrect reading on the tester on all outlets after the open neutral.
SOURCE: manual transmission stuck in reverse in my mx-5
You will have to remove the center console and then the shifter asm. look down inside where the shifter goes and you will see 3 selectors one will be out of position. You will need to pop it back inline with the other 2. After that look at the bottom of the shifter ther should be a bushing on the very end, if it is not there you will need to get one from your dealer, they are like 8 dollars and then you just pop it on and reasemble in reverse order and you should not have any more trouble.
SOURCE: Mini Split Heat Pump wiring
Check to make sure it is single phase, should be stamped on unit. Is this wiring coming from what use to be there?
If you replaced the old unit with this one, you can trace the wires back to the breaker box. If you are Electrically inclined or you know someone who is.
Remove the panel and trace the nuetral and ground wire to the bus termination.
Some States require or use to require that the nuetral
and ground wire be tied together. 230 is 230v ,2hot and a ground.
My guess is you tie nuetral and ground together or
I wouldnt use white wire and I would disconnect
from both ends.
If you are uneasy about electricity, talk to a certified
electrician. Contact City Electrical Inspector. Dont get hurt!
