#7465625*746*Code# = Disables SIM lock - what is the actual "code" to use here?
Try All this you can do...
*7465625*746*Code# = Enables SIM lock
*2767*2878# (Temporary Unlock)
*7465625*638*00000000*00000000# (Set Code)
#7465625*638*00000000# (Clear Network Lock)
*#7465625# (Verify the network lock is “inactive”)
*2767*3855#
*2767*3855# - FULL E2P RESET
*2767*2878# - CUSTOM E2P RESET
#*7337# - UNLOCK
*2767*688# - UNLOCK
*#0523# - CONTRAST
*#9998*523# - CONTRAST
*#8999*8378# - Service Menu (X100)
First with different carrier SIM in phone at WRONG CARD screen ENTER on the keypad
*2767*3855# (wait 10-15 seconds) phone will reboot(restart)
When phone completes reboot ENTER
NEXT ENTER
AND THEN *#7465625# to check the locks....all locks are inactive...these are all the locks...
network lock - inactive
subset lock - inactive
sp lock - inactive
cp lock - inactive
sim lock - inactive
activa lock - inactive
phone lock - inactive
auto network - inactive
auto subset lock - inactive
auto sp lock - inactive
auto cp lock - inactive
I WAN TO SOLVE MY PROPLEM
1100insertsim and 900mhz sim network no
My guess would be "7465625" is the "code". *746* is the preset number you need to call to unlock the code.
If that does not work, unfortunately you need to call your service directly. Try 611 or call them on a another phone at their customer service number.
28562
Menu fashion
The code that you are looking for is a 16 digit code that is unique to each imei and can be provided by the original phones network
SOURCE: Samsung SGH-E370 Sim Lock
http://gleez.com/articles/did-you-know/samsung-secret-codes
here u can find codes..
Before trying anything else, contact your service provider and ask for an unlock code.
Usually, if you've been a customer of theirs for some time, they will provide you with an unlock code for free. This is, by far, the best way to get your phone unlocked.
Download software to generate the unlocking code. Software is available on some websites for free and some pay websites that also offer support if things go wrong.
See external links below.
Find the Serial number of the cell phone, also known as your IMEI number.
Using the software you have downloaded, enter in your Manufacturer (which is in this case Nokia), your model number, and your IMEI number.
Also enter your country and the Network. Calculate the code, this may be different depending on which software you are using. If your phone is the Nokia 6300phone, select the model 6300, they are the same phone.
#pw+403927744443466+7#
Remove the SIM card from your Nokia phone.
This is typically done by removing the back cover of the phone and removing the battery and sliding the card out. Put the battery back in and power the phone on.
You will see a message "Insert SIM Card".
Enter all of the characters you see in your code, including the # symbols.
To get a 'p' press * 3 times, to get a '+' press the * key 2 times, to get a 'w' press the * key 4 times.
Disregard any spaces in the code.
In order to unlock your phone you generally need to enter only one code.
Start with the first one. If your phone is not unlocked by typing the first code (MCC+MNC), use code "7" (Multilock)
Once you have finished entering a code that works you should see a message that says "SIM is not restricted" or "Restriction off" message depending on your model.
If not, try entering another code. Message "Cannot undo restrictions" means the phone is "hard-locked" and cannot be unlocked by code.
Tips
Unlocking only applies to GSM phones, phones using other cellular technologies, cannot be unlocked without special software and hardware.
Switch off the phone. Hold the keys "3", "*" and "Call" and switch the phone on. Keep the buttons held down till you see the word "Formatting..." on the screen. Make sure that the battery is full charged before you attempt this. This should reset the phone lock code.
Warnings
Attempting to unlock your phone is done at your own risk.
Although unlocking your phone is legal, some cell phone operators might choose to void your warranty should you unlock your phone (then again, some cell phone operators won't mind).
Most phones only allow you to try a certain number of unlock tries, Nokia phones have a limit of 5 tries.
After that, the phone becomes "hard-locked", meaning it cannot be unlocked without using special equipment.
Most of the newer phones will not work with the codes generated by the free unlock programs.
You can get a free unlock code generatoe software free from here :
http://unlock.nokiafree.org/
You can also download from here :
http://unlock.nokiafree.org/NokiaFREE_v310_Nokia_unlock_codes_calculator.zip
You can check this :
http://www.wikihow.com/Unlock-Your-Nokia-Cell-Phone
Good Luck.
Live, Love, Laugh.
doc,have got da same problem
all othe are inactive accept "sim lock" - remains active
i have been given a code "#pw........." - I can enter the "p" but how do you enter the "w" without a sim card in?
i need a code for the password for where its sayz #7465625*746*code# so if someone can help me plz
I have trouble with my fone. Everytime I insert a different sim card apart from mine, it allows me to enter the PIN code, but then it later on asks me to enter the sim lock code, I guess I have forgetten that code right now. How can I remove SIM Lock from my sumsang SGH-E370 fone? PLEASE HELP ME!
i have the same samsung SGH E370 and evry time i put in the sim the phone showing simlock please some body help me to unlock it i love it n i would to get the code for it this is the imei 354322011458833 please and thanks
please tell me what is the code of network lock...
رمز
I have a problem with Samsung SGH-E370..how can i unlock the sim..and what should i do if the phoe ask me to enter network lock..
