Here is a contact link and phone numbers. Perhaps it will be of use in acquiring the procedure or a manual.
https://www.cyclopssolutions.com/contact-us
SOURCE: Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
SOURCE: Changing the park and spotlight bulbs on 1996 Impreza WRX
i had the same problem with my 2003 wrx you have 2 choices on how to fix it the first is take the car to a subaru dealer and they can do it for you. Or you can do it yourself like this under the bonnet at the front of the grill you'll see a row of clips first you have to pop them out to remove the grill fully from the car that will give you access to the 3 or 4 bolts holding the light to the car you have to undo these bolts and remove the entie light from the car this will give you fully access to the park light fixture simply twist it so it pops out the headlight and replace the bulb ..... the spot lights are the same remove the grill and the headlight from the car this makes a gap if you look threw and down this gap you will see the back of the spot light fixture simply twist (unclip it depending on the year of the car) it to remove it and replace the bulb once you have done this bolt the headlight back in and clip the grill back into place
SOURCE: cyclops spotlight wont charge
It is indicating that your battery needs to be replaced, it will not hold a charge.
SOURCE: I need 3 light bulbs for a 3 million candle power
Hello! I have a marinepro, 12-volt, 3 million candle power spotlight (mpn #MPAT-996). I found out that the manufacturer is RoadPro (866) 622-7979. After contacting them, they said the replacement bulb is an "H3 12v (volt) 100w (watt) and can be found in the Walmart camping section or should be available at any car parts store. I'm going to go to Walmart to find mine. Hope this helps others!
SOURCE: how do i find charger for cyclops 15 million candl...
INPUT: 120VAC 60Hz 18W
OUTPUT 12VDC 1A.
This is the spec for the 18 million thor cyclops which i presume will be the same for the 15 million.
Red light on torch flashes while charging. As soon as full charge is done red light stays lit.
