Spartan brand curved glass shower unit we have had for 10 + years. We just replaced the sliding curved door (I planned ahead and bought a spare one at time of installation ) but the new clips don't run well in the tracks. Anyone have the ''how to'' for proper installation? We just guessed how to do it as the instructions are long gone... I didn't plan that well enough! The door will almost close (1 inch short) and will almost open (about 2 inches off). The company is no longer around. It has a white base, with frosted glass, one fixed side and one sliding side. The sliding section is on a ''track'' attached top and bottom by small black clips that each have a roller wheel.
Curved cut glass will not always be the exact dimensions though they may look identical there should be several set screws on both the door glass frame and the shower glass frame that can be loosened and reset to make the door fit and close and open more properly without seeing the showwer itself i can not tell you exactly where they are but they should be either visible or behind a facade piece of metal frame
Testimonial: "Thanks. I will try tinkering with it a bit more and see if that works better. :-)"
