I have white a1136 video 30 gig i pod and i can only hear out of one side of ear plug. tried ear plug in other music players and works in all but my i pod. has to be something wrongwith I pod, pkease help
Your assessment seems to be correct. The problem is most likely in the iPod.
The stereo headphone connector (called a "jack") may have a broken connection, most likely on the Printed Circuit Board (PCB) inside the iPod. You may try carefully wiggling the plug in the jack and see if the sound comes on and off. Do it with the volume low so you don't damage the amplifier in the iPod.
I have opened them up before. It can be done, but is not particularly easy, and must be done carefully.
If you are technically inclined, or know someone who is, open the iPod and examine the jack connections to the PCB. If there is a break, it can be repaired by soldering a wire across the trace on the board.
If you're not able to do this and don't know anyone who can, it will probably have to be professionally repaired if the warranty has expired.
