Ovens Logo
Jen Thompson Posted on Jul 12, 2019
Have a Whirlpool Accubake, when you set the oven temp, it heats up, but gets much hotter, burning whatever I'm attempting to cook.
Lukas Alexander
Level 1:
  • Contributor 21 Answers
  • Posted on Jul 12, 2019
Lukas Alexander
Contributor
Level 1:
Answers
21
Questions
0
Helped
20315
Points
31
The temprature sensor curcit check it
  • Jen Thompson
    Jen Thompson Jul 12, 2019
    Thank you so much!
Whirlpool accubake model WFG371LVS2. Set bake to 350, meter reads 465 before shutting off. Thermostat and control panel have been replaced. Is this a proper temp swing?
Could be oven temperature sensor.
https://www.searspartsdirect.com/part-number/W10181986/0022/664.html?modelNumber=WFG371LVS2&categoryName=Free%20Standing,%20Gas&brandName=WHIRLPOOL
I have a whirlpool accubake electric oven. how do i adjust oven temp?
with the on switch for the oven the higher the numbers the hotter the oven
the thermostat will do the controlling at the temp you set
If that is not happening replace the switch
2answers
Whirlpool Accubake Wall oven pre heat but temp goes 350 and downwards when pressing temp up
I am not sure about this, but sounds like a connector is on backwards or in the wrong place.
Temperature when using frigidare oven, keeps getting hotter and does not cool down
Good Afternoon Andrea,
I see that you're having issues with your Frigidaire oven, and the heating element being red hot the entire time you were cooking no matter how much you turned the temperature down.
I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your oven, you will need to set the clock by entering in the time and pressing start. Preheat the oven, to whatever desired temperature, and if it is still running hotter than it should be, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Oven will not maintain heat
possible thermostat problem in the switch
call the technician or get the part from tyhe servide agent spares
1helpful
I have a whirlpool accubake duo, super capacity 465 and when I try to bake something the oven wont stay on...how do I get the oven to stay on
What do you mean that it wont stay on? Does it turn off and on during cooking? Does it just go off and wont come back on? The oven thermostat regulates the heat in the oven and the oven element and the oven indicator light will turn off and on during cooking. If it stayed on constantly on full oven element power everything would burn.
Whirlpool accubake oven (elec) E-2 F-3 fan running oven wont't heat all other functions normal
Hi, your oven will not heat if the temp sensor is faulty or damaged. this code represents a non-responsive oven temp sensor.
Replace Oven temperature sensor (RTD)
Aug 15, 2009 • Ovens
Oven hotter at the back
You should always preheat oven to operating temperature before cooking anything.
Do not put too much in oven, leave plenty af space for good air circulation.
Do not place any reflective foil or the like on the bottom of oven or shelves, as this reflects heat, and you will get uneven cooking.
Make sure fan is working efficiently if it is fan assisted.
21helpful
2answers
Whirlpool accubake oven troubleshooting
electric oven heats to correcect temp then drops and does not get back too appropriate temp. For example, set at 400, gets there then drops to 275-300
Dec 18, 2007 • Ovens
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
