Question about Watches
Need a charging cable for my wrist watch. Help.
  • Jean DeLauche
    Jean DeLauche Jul 12, 2019
    Hello, Terry - What is the make and model of your wrist watch? I want to help you with your question, but I need more information from you. Please add details in the comment box
2 Suggested Answers
SOURCE:
SOURCE: athletic wrist watch stuck in 24 hour mode
Maddening, isn't it? Fortunately the solution is here:
http://www.ehow.com/how_5593310_set-athletic-works-watch.html
1 There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
3 Press the start button to change minutes.
4 Press the reset button again to switch to hours.You will know it worked when the hour starts blinking instead of the minutes.
5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
Posted on Jan 05, 2010
I currently have a Relic ZR11971 automatic skeleton watch and earlier this week, I noticed that it had simply stopped working. The "Pendulum" will not move unless I swivel the watch back and forth a couple...
You watch is automatic , which means as long as it's on your wrist and moving it will run. If you have it on your wrist and shake it a little then stops , then it will most likely need internal cleaning. Unfortunately nowadays watch repair shops charge around $35 - $45 to do this task. That's the price here in Florida, I am not sure where you live. I hope this helps
Marcelo
Oct 23, 2013 | Watches
I need to find a wrist band for my Armani Watch AR0210. Can you tell me where to find a replacement wrist band and the cost of it... Thanks
first i have to know your location. but this model of armani watch strap is can be replace by any brand of strap not only armani brand but if you like a armani strap brand, you have to order it at authorized retailer of armani watch. i hope this will help you.
Aug 12, 2011 | Giorgio Armani AR0210 Wrist Watch
Can't adjust the wrist band on citizec C651
Look where the band connects to the fold-over clasp. There are several holes on the clasp. Use a plastic headed thumbtack or some other small pointed object to push the pin in and move to desired hole to fit your wrist.
If the longest adjustment is still not big enough you will need to add a link to the band. You can contact Citizen Watch at 800-321-1023 they will send you 3 links at no charge.
Oct 21, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Citizen Aqualand eco drive divers watch.
Give the watch a good charge under a lamp for 24 hours , not close to the lamp so it get real hot.
if it does not hold charge after this i would contact Citizen as the capacitor may be faulty.
Aug 25, 2017 | Citizen Eco-Drive Aqualand BJ2004-08E...
I need a strap for my watch, because it broke. can anyone please help me?
Just about any watch shop or jeweler will have a nice selection of replacement straps in whatever style you prefer and they will typically install the new strap you buy from them at no extra charge.
Apr 23, 2010 | Calvin Klein k2151.20 Wrist Watch
I have a Citizen Eco drive waterproof wrist watch with four buttons and no ''winder'' can I get instructions for this watch
The eco drive means that it charges the battery using artificial light or sunlight, there is no need to wind as the battery never runs out of charge providing you keep it in light.
Oct 19, 2009 | Citizen Eco-Drive Aqualand BJ2004-08E...
Does not hold charge
Hi
You will need to take it a watchmaker as the capactor is most likely gone in it and will need replacing. I am also assuming that you are an activity person and swing your wrist lots?
Kind Regards
Scott
Jul 14, 2009 | Seiko Titanium SMY042 Wrist Watch
Citizen wrist watch stops working
A lamp may be to hot while the light may not be sufficient. Put it in a window sil for a week or so.  Look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
May 25, 2008 | Citizen 8700 BL8000-54L Wrist Watch
Shortening the Length of a Metal Wrist Band
I just did this for my wife's new Kenneth Cole wrist watch rather easily. You don't need a screwdriver, but a short section of a paper clip will do. I just set the band on a raise surface to allow room for the pin to be pushed out using the paper clip. For this watch, one side of the pin resembles the slotted side of a small screw - but it is not a screw. This is the side that bulges up a bit to help the pin stay in place. I believe if you punch it out from the opposite side it will fall off quickly, but if you do from the bulged side it, too, will come out but with some resistance. To reattach the band you need to punch the pin into the slot in such a way that its bulged side is on top otherwise you may end up with a bent pin. You must also first line up the hole with the paper clip before reinserting the pin. Good luck.
Nov 06, 2007 | Kenneth Cole KC3289 Wrist Watch
Watches Logo
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
