Dryers Logo
Azad Sattar Posted on Jul 12, 2019
My Electrolux drier mod#eimed5511wo is showing an error code of E64 cuts off about 5 minutes after it is started
Tyler T
Level 1:
Habit-Forming:
  • Contributor 35 Answers
  • Posted on Jul 15, 2019
Tyler T
Contributor
Level 1:
Habit-Forming:
Answers
35
Questions
Helped
27131
Points
95
E64 is a shorted element. It can be caused by other things such as the control board or thermostat but it is almost always caused by the element warping and touching it’s housing. The element would need to be replaced. The element is ~$130.
Rudy Lorenz
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 15 Answers
  • Posted on Jul 12, 2019
Rudy Lorenz
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
15
Questions
0
Helped
13175
Points
19
Contact the manufacturer and find out what the error code is for.
5 Related Answers
Anonymous
  • Posted on Apr 25, 2009
SOURCE: 2001 Buick Regal cuts off while driving at times also won't start
The ignition switch on that model is rated @ 50amps. When I was driving my 2001 Regal LS (at 120,000 miles) and used the turn signal, the engine would die, when I switched the turn signal off, the engine ran. So I replaced the ignition switch, and all is well.
[email protected]
protek480
Craig Butler
  • 1730 Answers
  • Posted on Sep 25, 2009
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
petraman7
Scott Frye
  • 1175 Answers
  • Posted on Jan 26, 2010
SOURCE: Yamaha T100C Amp ...volume cuts out after 5 minutes.
Hi...
Looks like a tube amp.
Get the tubes tested. The tubes themselves should have a dark chrome appearance on the tops and maybe a couple spots on the sides. If there's any gray or milky appearance , then the tube is bad.
Let me know how you fare
Anonymous
  • Posted on Dec 18, 2011
SOURCE: error code on a Frigidaire affinity dryer E64
Heating element wire malfunction.
richroth
Richard Roth
  • 9472 Answers
  • Posted on Oct 21, 2012
SOURCE: frigidaire affinity electric dryer says error E 64, what does that mean?
Heater has an open circuit and need to be replaced. Here is the part you need.
2answers
Error code e64 dryer Electrolux FFSE5115PW2
How to Fix Electrolux Dryer Error Code E64
Appliance Express https://applianceexpresstx.com > News and Tips
Apr 10, 2023 - If your Electrolux dryer is showing an E64 error code, this means there is a problem with the heating circuit. When this occurs, your dryer ...
Common Electrolux Dryer Error Codes & How to Fix Them
Just-in Time Appliance Repair https://justintimeappliance.com > blog > common-elect...
Feb 3, 2020 - Another of the more common Electrolux dryer error codes, E64 indicates a malfunction with the heater's wiring or the heating element itself.
How To Fix Frigidaire & Electrolux Dryer Error Code E63 E64
howtofixit.net https://howtofixit.net > how-to-fix-frigidaire-electrolu...
Oct 18, 2020 - These E63 or E64 error codes generally mean that you have an issue with the heating element ...
Videos for E64 Error.
How do I get rid of code? I have an Electrolux front load dryer model #EIMED55IIWO, with E 64 error code. When initially starting the dryer I cancel the code and start the dryer.
E64 error code Electrolux dryer! E64 fault code on your home Electrolux clothes dryer. What this code stands for is that you have a shorted heating element. Other Possible fault: Heater thermostat faulty: Wiring faulty; Electronic board faulty.
https://advancedappliancesolutions.com/e64-error-code-electrolux-clothes-dryer/
https://www.youtube.com/watch?v=ErDSsjVywwg
E64 error code electrolux dryer
You have not specified Tumble dryer model so I can not say for certain that my answer is correct. Fault codes can sometimes vary depending on the platforms appliances because today some manufacturers release new models twice a year and thay have the absolutlly right to make changes and improve the efficiency of new appliances (also change fault codes).
E64 - Heater thermostat
  • Thermostat faulty (replace heater unit)
  • Heater unit faulty
  • Wiring faulty
  • Electronic board faulty.
Dado
2answers
What is an e64 error code on electrolux dryer ewmed70jss?
Good Afternoon Friend,
I understand you are receiving an E64 code on your Electrolux dryer, model# EWMED70JSS, and want to know what it means. What this is stating is that there could be a possible issue either with the heating element or some wiring. It could also be a possible false error code. I suggest resetting your dryer, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
1helpful
E64 error code
Hi gordsxbstn34 - Typically error code E64 indicates that the unit has detected that the heater circuit is open. Contact a professional to move forward accurately to check the heater coils and connections for open circuits. Depending on the diagnoses heater might need replacing and/or wiring
7helpful
Error code e64
Hello Gary Melton - Typically error code E64 indicates that the unit has detected that the heater circuit is open. Contact a professional to move forward accurately to check the heater coils and connections for open circuits. Depending on the diagnoses heater might need replacing and/or wiring
Top Electrolux Dryers Experts
vince
NOEL
NOEL
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
