The Error Code oxc0000225 shows up after an update from OS, including upgrading from Windows 7 to Windows 10. The issue is the incorrect system disk. This can even happen if the PC turns off system files or even faulty equipment after a significant upgrade. You can't fix this problem from the inside of Windows, like other boot mistakes. But you would need to get a convenient Windows 10 disk upgrade tool for repair.
Just go through the link of a blog and follow the procedure.
View the blog:- Error Code oxc0000225
If you are receiving an error when sending email using Outlook:
"The message could not be sent because one of the recipients was rejected by the server. Server Response: '550 not local host, not a gateway', Port: 25, Secure (SSL): No, Server Error: 550, Error Number: 0x800CCC79"
Open your Outlook settings (Tools > Accounts) Go to View/Change email account for the email account you are having problems with. Check that the SMTP Server is set to yourdomain.com Go into the "More settings", "Outgoing Server" tab and make sure that the option "My server requires authentication" for the Outgoing server is checked ON.
Save and close all windows.
Try again.
If the problem continues then the problem is that your Internet Service Provider is blocking the mail server. ISPs do this to prevent spam on their network. When this happens you will need to use the mail server that they provide you instead of your own. The mail server is generally smtp.yourISPname.com, however, it could be different so please contact your ISP to get the details. If you do not want to use your ISPs server for SMTP, and the ISP is blocking port 25, you can switch the port to 587 for your outgoing mail and use mail.yourdomain,com for the SMTP server name.
