You can find a service manual for the pronto and 41 at www.invaCare.co.uk/sit ....
On page 15 under troubleshooting it says all LEDs are flashing slowly if the definition joystick has detected an out of neutral at power up mode so what you do for the comment is to release the joystick back to neutral. Hope this
SOURCE: manual for Pronto M51 wheelchair
Hi. We can supply, but try your local Invacare dealer. If you have luck, send us an email,
[email protected]
SOURCE: my pronto m5 power wheelchair blinks red when
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
SOURCE: Pronto M51 Wheelchair doesn't have as much power as it used to. Batteries are good.
Have you had the batteries load tested? How do you know the batteries are good?
Testimonial: "Took the batteries back to Batteries Plus and had them tests. Load test was good but the capacity test showed batteries should be replaced. Replaced batteries but chair drives slower then it did with the bad batteries....barely moves when on low setting. "
SOURCE: blinking wrench light on an invacre pronto m41 power wheelchair, what does this mean?
Hello,all the info you seek will be found in:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772.Download it as a PDF File,36 pages full of info.Page 19 to 36 focuses on what you ask for.I am sure you will be happy with what you see,take care.Colin
SOURCE: What does eight flashes of the wrench indicator mean on the invacare Pronto m 41 power chair
A flash code of 8 indicates a computer controller problem. Check all the connections at the controller under the rear cover. A rebuild or replacement of the controller is probably necessary. Hope this helps.
The AMBER service indicator will light when an error or fault occurs. This is a yellow wrench shape. Refer to Diagnostic Codes on page 33 for a listing of the flash codes and what they indicate:
https://www.phc-online.com/v/vspfiles/V4_Backup/docs/MK5-NX_Electronics_Manual.pdf
