Boating Logo
Anonymous Posted on Jul 11, 2019
What prop for df70 Suzuki outboard - Suzuki Boating
Gary F
Level 2:
Sergeant:
  • Expert 258 Answers
  • Posted on Jul 11, 2019
Gary F
Expert
Level 2:
Sergeant:
Answers
258
Questions
Helped
66083
Points
672
Did you lose it or can it be repaired?
3 Related Answers
Anonymous
  • 53 Answers
  • Posted on Nov 01, 2009
SOURCE: 2001 suzuki outboard water prop
water prop? if your talking about the Propeller that rotates to propel the boat. only replace it if fins are missing. Aluminum and stainless steel propellers can be rebuilt. If your talking about the water pump impeller. the answer is yes. its rubber and should be replaced seasonly
Bill Eager
  • 460 Answers
  • Posted on Sep 15, 2010
SOURCE: Suzuki 2 outboard, can't get
Aluminum prop??
Try,
Heat
liquid wrench
vinager
take you time, it will come loose sooner or later.
Anonymous
  • 184 Answers
  • Posted on Oct 14, 2012
SOURCE: Suzuki outboard 8hp 1994, at higher speeds under loading prop appeared to cavitae, liek spun prop. repalced with new prop. On the bench, plugs removed, in forward gear hand turn prop thur haft turn a
You may not be deep enough in the water and it really is cavitation.
May want to check the lower oil for metal as a Mostly worn out gear can do that
It's normal for a gearbox in forward to "click" in one direction and be firm against the motor when turning against the gears normal rotation.
1helpful
What year is my Suzuki DT15C outboard engine. model number 01502 351906. Which exact model of replacement propeller does it need?
if you are happy with current propeller then take prop off lower unit and look on the backside of the prop..it should show size and pitch close to center
1helpful
Suzuki outboard 8hp 1994, at higher speeds under loading prop appeared to cavitae, liek spun prop. repalced with new prop. On the bench, plugs removed, in forward gear hand turn prop thur haft turn and...
I have a 2007 Suzuki df70 4 stroke outboard motor that when put in a higher gear than trolling sounds like a tapping noise coming out of motor, also a loss in power.(noise sounds like a card that a ki
Most manufacturers demand the water pump be changed every 3 years.
If your thermostat sticks, you can over heat. You would also need to ignore or have a failed temp buzzer. Also at extreme temps, your temp sensor can burn up. SO if you heard the buzzer, and then it quit- that did not mean you were out of the woods.
If you could still run on your scalded pistons, I would think a light bore job with new pistons would fix it.
Suzuki 2 outboard, can't get the prop off, it's seized, any idea how to remove it?
Aluminum prop??
Try,
Heat
liquid wrench
vinager
Sep 14, 2010 • Boating
I have a 4o hp outboard marinier and when u give it about half throtal or more it acts like its slipping,
It is most likely a damaged prop. If the gear shift handle is steady while it is slipping, Your prop needs to go to the shop for a re hub. Take a punch and mark the center of the prop (the hub) ,then mark the blade of the prop in alignment. Try it out and see if the marks still line up. If they have moved- the prop is bad.
Top Suzuki Boating Experts
jws1013
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Suzuki Boating Expert? Answer questions, earn points and help others
