SOURCE: 31-735 delta belt/disc sander - dust collection nightmare
The belt cover that does down the front of the belt, below the table, should have an opening inside the baes/vacuum unit. Make sure this isn't clogged with buildup.
SOURCE: dust bag won't collect
Try blowing through the little **** that collects sawdust (inside back by belt) with a compressed air nozzle, with the bag off, and squeeze the trigger and let the motor run a little. Blow out the insides as well as you can, including the air intakes for the cooling of the motor, and it should work fine again.
You can also blow out the bag to clean the pore in the fabric.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
SOURCE: Makita Belt Sander 9404
the tool needs cleaned thoroughly. there might be a section of a belt that has jammed the passageway. UNPLUG the tool and turn over to see on the backside if the clog is there, if not I would recommend using safety glasses and compressed air to blow thru the channels to dislodge the material. I havae also used a shop vac to help in this.
SOURCE: I have a Mastercraft random orbital sander Model
I just had the same problem. I couldnt find any information online.
call the toll-free help line
1800-689-9928
Tell them the make of the sander and what kind of part you need. They will look it up and ship it to you in 7-10 business days
