Hi I have Acer MF 350 Drive and its suddenly not getting access on my vista operating system.
Error Message I/O Device Error...Any suggestions how can I fix it up.....
Please email me if u can on ([email protected])
Thank You
I/O Device error problem
T.sonic cannot operate after it was formatted in Windows Formatting T.sonic using the “Quick Format” or “Full Format” option in Windows destroys the default format of the T.sonic. To retrieve the default format, you must link to http://www.transcendusa.com/ and download the firmware updates for the T.sonic.
You may have to get a CD/DVD of Vista from your friend or associate for reinstallation of the operating system. If you go to Windows 7 or 8.1 you would be better off than waste time with Vista and all of its problems. If the CD Drive is not working, get an External USB CD/VDV drive from WalMart. They are not expensive and they come in handy at times. Plug the external CD/DVD into a USB port and start up the computer seeking the new device. Run the Software the same as you would from your unstable device.
This error comes out when the pc cannot find the hard disk. Does the bios detect it? What is the exact error? If the error you get is NTLDR missing you should install again the operating system (i.e. Windows) If the error you get is no bootable device can be an hardware problem. Please check the connection of your hard disk. If connection is good you may want to remove the hard disk and buy a new one. The old hard disk you can put into a usb drive and copy your personal data so you can have it back. If with the new hard disk you are not successful it could be a motherboard problem and you should take it to assistance
Your CD drive or DVD drive is missing or not recognized by Windows or other programs, so you cannot play or access a CD or DVD. This issue might have occurred after you installed, uninstalled, or updated a program or Windows Vista.
This issue may have occurred after one of the following situations:
You upgrade a computer to Windows Vista or install Windows Vista Service Pack 1.
You install or uninstall CD or DVD recording programs.
You uninstall Microsoft Digital Image.
You may see one of the following error messages:
One of the following error messages appears when you view the CD drive or the DVD drive in Device Manager.
Error message 1
The device is not working properly because Windows cannot load the drivers required for this device (Code 31). Error message 2
A driver for this device was not required, and has been disabled (Code 32 or Code 31). Error message 3
Your registry might be corrupted. (Code 19)
An "error code 39" error message.
A message that resembles the following appears in the notification area:
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
you can find this information and more at this site..
Make sure that hard drive is detected in BIOS. If not, there is a problem with the hard drive and any attempt to install OS will be futile since there is no hard drive detected. If this basically means you have a busted hard drive, you may need to replace it then to continue with OS installation.
I/O Device error the o/s itself is not reading it as a removable disk......
I too have the same problem kindly let me know the solution for the same
