Ws-55311 turns on and then turns itself off in 3 seconds or so. wont stay on
No, if blink code the problem is in the TV set--cable will not cause this type of trouble
Testimonial: "this is a neat site...and quick with the responses..will use again"
Turn on ws-55311 and stays on for 20 seconds and then shuts down. turn on again for another 20 sec, goes down then th screen goes black with wavey lines through it.
it has 2 blinks and then 1 blink. I did it twice to make sure it wasn't 2-2.
could a problem with the cable cause it? Our cable provider has been out and is coming again tomorrow due to fading in and out of the picture and a signal problem with the box that he supposedly fixed.
repair man came out, it needs a new power board, it is $6-700. If it had been around $300 we might have gotten it fixed, but think will look for an LCD.
two blinks and then one blink is error code for X-ray protection---means problem is most likely in the High voltage circuit of the set---the set will detect something is not right and shut down----a lot of possible causes for this----someone needs to go into it with a schematic and start looking for shorted parts in the High Voltage circuits.
set has self diagnostic feature; when it goes off press and hold Menu & Input(device) buttons on front of set for at least 5 seconds and then release both together---set will (power light) then blink a two digit code----ie: two blinks, a pause and two blinks is 2-2 which is the most common error on this set---let me know what you find and I will tell you what it means.
