My dryer overheats and shuts off. I have checked the venting and it is clear. It gets so hot that is has melted my clothes and the lint screen frame. I just keep resetting it via the button on the back.
Well, if the vents are perfectly clean and unobstructed the only thing I can think of is that the thermal switch designed to turn off unit when overheating is opening prematurely.
Might have to be replaced.
1) check and or clean you vent..
2) check air coming out of the vent...
a) if no air coming out or little amout of air ... check blower wheel ( remove toe panel. then remove blower cover.) wheel should be clean and clear ...
PS. there is a reset button on the back panel... black button about center..
hope it helps if NOT let me know more about your problem...
Common problem.
You probably need to clean your dryer vent. Dryer vents should be cleaned every couple of years to prevent them from being clogged with lint. You can check the air-flow by going outside where the vents terminate. What's probably happening is on sensor dry, there's a moister sensor that tells the machine to shut off when there's no moister. The hot is is being pushed back into the dryer and confusing the sensor. That's why it's working on timer dryer because that option bypasses the moisture sensor.
There's a reset button on the back of the dryer. It's a small black kinda rubber button about half way down the back panel near the center. push that button to reset it. should do the trick.
I had the same problem. Turns out the reset button on the back of the dryer needs to be pushed; when you push the reset button you should hear a click. If you do not hear a click the problem was probably not the reset button. The button shuts down the dryer heating elements if they are getting too hot and also keeps the drum from turning unless the start button is held down.
If you push the reset button and the dryer starts to work again, I strongly recommend that you stop the dryer and investigate why the heater elements overheated. In my case there was lint/hair build up on the heater elements themselves. Extensive dryer disassembly is required to properly clean the heating elements but it is worth the prevention of a house fire. While you're at it, clean the rest of the machine and the duct work.
