Proline dfv152l-2 (digital reciever) i made a channel/program scan, and the receiver found alot of programs ....my question: i want to sort the programs by my way from 1-20 so that is my choosen program on remote-control no. 1 to 20 ....is that possible??? sorry for my terrible english...iam a german ;-)...thanks in advance
SOURCE: programming the directv remote to program a sony audio receiver
Go through the process of setting up the remote again instead of trying the volume first use the power off button. In my experience, Sony receivers can be picky and power cycling "will" insure the code set, then try the volume.
SOURCE: Remote control code to program for directv receiver
i have a ton of codes i need your model# of your Directtv Receiver.
SOURCE: How do I program a Directv remote witha Samsung Directv receiver
http://www.directv.com/DTVAPP/global/contentPageIF.jsp?assetId=P4380052#h:1020.989
there is the website, put in the name of the receiver as Samsung and make sure you are under "SATELLITE SET TOP BOX" and follow the instructions on programming. hope this helps!
SOURCE: can't program rc65 directv remote to control
I believe the codes 00001 and 00002 are valid for all DirectTV receivers.
Instructions for entering the codes are here.
Instructions for searching for the proper code if those two don't work, or for other devices, are here.
If you'd like a digital manual for your RC65, click here.
I hope that helps.
SOURCE: Ref: Motorola DCH3200 Problem with channel input.
Unplug the comcast digital box and wait 20 seconds or so, then plug it back it. I had the same problem and was given this solution and it worked. NOTE: the program guide will require at least 24 hours to "fill up" again. I was told that the problem is that the cpu in the digital box gets overloaded and needs to be rebooted/reset.
Hope this works for you
