Question about Nintendo Wii Fit - Balance Board + Game Console
Wii Fit not registering movement - right side of balance board
When I am hula hooping to the right the hoop just falls to the ground as no movement ( no matter how hard I hula!!! ) seems to register - hula hooping to the left is as before - registers correct amount - what can I do? - it's pretty frustrating!!! For the past few months everything has been OK this problem has suddenly developed...
2 Suggested Answers
SOURCE:
SOURCE: Wii Fit Hula Hoop does not register on rotating to the right
you rotate left your hula hoop same your body and you move the hula hoop with your body
Posted on Feb 04, 2009
How do you get the weight balanced in a hula hoop?
A hula hoop is not designed to be repaired or serviced. If it has failed you need to dispose of it and purchase a new one.
Apr 17, 2012 | Sewing Machines
"communications with the Wii balance board have
Ok, that only happens when there is something blocking the signal to your Wii's antenna. Try moving the balance board further away from the television.
Dec 17, 2010 | Nintendo Wii Fit for Wii
New crown compatible wii fitness board will not sync with wii console. board only blinks a few times then switches off
Have new crown compatible fitness board, new batteries inserted, inserted Wii fitness disc, choose training, then trial, choose hula hoop game, used remote press A to start.
Screen says place me on a flat floor and press POWER button before stepping onto me
Followed the instructions power button flashes blue, as do the four corners then the lights go out - then nothing happening, still have the same message place flat on floor etc....
Have also tried the Wii Balance Board Check - followed all instructions last one says please turn on power. Pressed button flashes blue as do four corners then they go out
Am I doing something wrong or Is this a faulty board ?
Thanks
Sep 27, 2010 | Video Game Consoles & Games
USING THE HULA HOOP
The trick to hula-hooping is timing. If you get the hoop moving fast on its initial turn around your midriff you have a better chance of getting the timing- I like to use my legs to get the hula just right... And remember- the slower the body moves on the timing, the faster the hoop hulas.
Oct 07, 2009 | Balance Health & Beauty
Wii Fit - Hoola Hoop
If you're not shifting enough weight to one side, you can't catch a hoop. I have found that lifting the opposite foot off the board as soon as the toss is thrown helps quite a bit.
If you're still having trouble, evaluate how the board works with other activities on WiiFit. If you notice problems in other areas, you may have a defective unit. There is a calibration feature on the program, and if that doesn't work, try opening up a trouble ticket on www.nintendo.com.
Feb 04, 2009 | Nintendo Wii Fit for Wii
Feb 03, 2009 | Nintendo Wii Console
Wii Fit instructions for movements are all in reverse
No it is not how Wii Fit is supposed to be. First, let me suggest that you ensure that the power button on the Wii Fit Balance Board is facing AWAY from the TV set. This may seem silly, but it's the most common error. As for the Hula Hoop game, make sure that your weight is all on the side of the Wii Fit Balance Board in the direction that you need to lean to catch the hoop.
There have been instances of the sensors in the Wii Fit Balance Board going out. If you have tried the above steps and you are still getting errors, please go to www.nintendo.com, register your product, and open a problem ticket with them.
Jan 28, 2009 | Nintendo Video Game Consoles & Games
Wii Fit Hula Hoop Game
try standing as far back as u can, then jump and then do twenty jumping jacks.
Nov 24, 2008 | Nintendo Wii Console
Wii fit does not recognize movement on board. This is a new problem. I've used the board and know how to move on it. Tried new batteries, recharged battery charger, re-synched, help!!!!!!
I called Nintendo and they said there are sensor problems with some of the boards. We had to send ours back, free of charge (they even paid for shipping) and had a new one within 12 days. 1-800-255-3700 is the repair and troubleshoot #....
Sep 05, 2008 | Nintendo Wii Fit for Wii
Nintendo Wii Fit - Balance Board + Game Console Logo
179 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
