Samsung HL-S4266W 42" HDTV Logo
Posted on Aug 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Numerous white spots on Smasung DLP TV
I bought my HL-S4266w in 2007 and it has been fine until yesterday when seven white spots appeared and later that day 23 spots appeared. Seems like a lot of people are beginning to experience this problem
skar23
Level 1:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 58 Answers
  • Posted on Sep 17, 2009
skar23
Contributor
Level 1:
Night Owl:
Answers
58
Questions
Helped
12798
Points
97
Above information is a bit extreme - most likely culprit is dirt/dust on reflecting mirror.....
  • skar23 Oct 02, 2009
    I ended up taking mine apart completely - the problem is indeed the dmd chip - Ill be calling around tommorrow to locate one (it is similar to replacing a processor on a pc mainboard)
coyotedave
Level 2:
Sergeant:
  • Expert 280 Answers
  • Posted on Sep 21, 2009
coyotedave
Expert
Level 2:
Sergeant:
Answers
280
Questions
Helped
111180
Points
557
1helpful
I have a 67" DLP TV and last night 2 white spots
That usually indicates that the optical block is going bad. That repair is usually 900-1100 dollar fix.
6helpful
Spotty tv
DLP/mirror chip is going bad. A common problem on Sammy TVs after 2-3 years. Chip is user replaceable (try samsungparts.com or ebay) for about $150-200. Sammy was (last year) repairing the DLP White Spot problem for free. You MUST talk to ECR (executive customer service) to even think about getting that consideration--forget the standard CS people. Don't know if they are still covering this out of warranty in 2010.
2helpful
Mysterious White Spots
Your projection lenses need to be clean including the lamp. Call the service technician in order to fix the problem.
4helpful
Samsung dlp tv hl-s4266w has white spots on it? How much to fix?
Are they spots or dots? If they are spots then the optics are contaminates. If they are dots either white or black then you have a bad DMD chip. The cost of repair depends on who you hire to repair the set or if you do it yourself it depands who you purcahse the part from.
1helpful
2answers
Mine is having the same problem. It started around Memorial Day and is only getting worse. One white dot is now a dozen. I called Samsung several times and was given the brush off. They clearly know this is a problem and are failing to respond to the problem in hopes that people will deal with it on their own. It does not matter if your warranty is expired. This is a latent product defect. They are still liable and obligated to fix the problem. I have filed a complaint with the better business bureau. If the company does not respond, I'm taking this to small claims court to get reimbursed for any cost to fix my tv.
7helpful
4answers
If your Mitsubishi TV has white spots in the picture , you can call Mitsubishi @ 1-800-332-2119 and request a free DLP Chip to fix the problem. They will send the New DLP Chip at no charge to a TV Tech in your area to install it for $200 flat rate. That is about a $250 savings if you had to pay for the chip . Call them with your TV's Model number and serial number and let them know when and where you bought the TV.
It saved me some hard earned money and now my TV is like New !
same problem for me ... check out this thread on AVSforums about it.
I have the same exact tv as you and had the same problem. I took it to a repair shop who told me I needed a new DMD chip and that it would be 850 to fix. I used the information in thread above to get the part number and bought the chip on ebay for under 200. Here is a link to the listing CHIP
People have had good success. I will be replacing mine tomorrow.
1helpful
BAD LIGHT ENGINE call UED 1-800-648-6657
4helpful
4answers
See link below for "field of stars" fix:
http://www.avsforum.com/avs-vb/showthread.php?t=1107926
Worked a charm on my 50" Samsung DLP. Read thread carefully as there are 2 different version of the DMD chip you will need to replace. I ended up fixing mine for less than $165!
Chuck
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
