Pairing the Headset
*You are required to pair the headset with your mobile phone or other device before using it.
1. Ensure the headset is off, then press down the P2 button until the pairing mode (both Blue & Red-LED's are flashing
alternately), then release. This will take about 6 seconds.
2. Initiate pairing process of your mobile phone. Refer to the manual of the mobile phone for the direction. You will see a new
item "BT headset" added in your Bluetooth device list after the searching process.
3. You will be asked to enter a pin code to complete the pairing. Enter 1234 and confirm. (Note: the 1234 is a default pin code
pre-stored in the Headset) The red indication will turn off and the blue indicator will flash slowly after the paring is completed
successfully.
4. Once the pairing is complete, the Red LED will turn off and the Blue LED will begin blinking, (indicating standby mode). If it is
not finished paring within 2 minutes, the headset will go into standby mode, and pairing is unavailable. You will need to restart
and repeat steps 1-3.
MANUAL HERE:
http://www.manualslib.com/manual/251101/Fonegear-976.html#manual
doesnt work
