Samsung HLR5067WX 50" Rear Projection HDTV Logo
Posted on Dec 04, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SAMSUNG TV MODEL HLR5067W
TV SHUTS OFF AFTER 4HRS. OR COULD BE 15 MINS. BUT YOU CAN TURN IT BACK ON BY HITTING POWER SWITCH ONCE ???
Anonymous
Level 3:
President:
  • Master 4,402 Answers
  • Posted on Dec 05, 2007
Anonymous
Master
Level 3:
President:
Answers
4402
Questions
0
Helped
1709991
Points
8129
Does the picture be frozen on screen for about one second before it cuts off. if so need new digital board
Hi there. i have the closest model, to LE-32B450C. Samsung LE-32C450. i guess..its europe model (im from greece). I bought the 32' TV a couple weeks back.. and now im messing with a shut down problem....
I have a few friends in the UK with the very same TV and no problem at all.
I would suspect either a power supply fault or a bad connection somewhere and I would return it for a replacement.
TV turns on/off automatically at 1-2 mins intervals.
Replace the power supply, PN: BN44-00206A
It's easy to locate, but requires adjustments once it is installed. Panel voltages must be adjusted according the the specifications of the TV. There is a sticker on the back of the plasma panel which provides each voltage setting. You can reference this sticker to make the proper adjustment. Using a DMM, connected between chassis ground and the panel voltage you are adjusting, turn the adjustments on the power supply very slowly, until you are measuring the specified voltage within 0.5v. I hope this helps and good luck.
Battery indicator keeps fluctuating to 4hrs to 6hrs back to 4hrs then 8hrs every 5 mins or so i have acer A0532H with windows 7
first of all let me ask how old is the battery, if it`s new-discharge the battery until pc shuts down itself because of low battery, remove the battery , unplug AC charger from laptop, wait for 5 minutes, then hold power button for 5 full seconds, wait another 5 minutes, then put battery and ac charger on , don`t turn on laptop yet, wait until battery indicator shows that battery fully charged, then remove AC charger, and turn on laptop. P.S. you can try this on old battery too, but usually worthless, because old batteries are not recognizable by system currectly ..
2helpful
2answers
Samsung hlr5067w shuts of after 30 seconds... flashes red
I would suspect the lamp first as they can cause intermittent shut down issues.
2answers
TV and Vedio-Projection televisions
what i would do is crack into the tv and watch the individual parts being careful not to unplug anything while you take the back panel off.....turn it on and see what happens. let me know what happens
Sounds like the lamp to me. The projection lamps get hotter as they age and the TVs have a sensor to monitor the temp and shutdown the TV if it get too high
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to buy just the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. Really easy.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
