I have your model DH5010A and it has started to freeze up just before the liquid enteres the first set of fins. It hardly catches any humidity. Does the compressor need some more gas? Can it be repaired. Thanks, Mickey
SOURCE: Dehumidifier problem
First, make sure the rectangular filter on the back side is clean so air can flow over the coils freely. Try to place the dehumidifier on a table or something to get it off the floor. (floor level is cooler than head level) If you still have icing issues, replace sensor. (part # WK23X10011 )
SOURCE: Dehumidifier Freezing up
Your dehumidifiers are LOW on freon. Over time, small leaks will occur and the coils will freeze. Take your units to a qualified repair shop (central air, or furnace) and recharge the freon.
SOURCE: kenmore 580.51650000 dehumidifier: compressor
fan should turn off when compressor not running, the relay switch is stuck open for the fan, and probably needs replacing, but even if it always runs there is no harm and it only uses like 15 watts
SOURCE: water freezes on fins but will not defrost automatically.
Here is a tip that will help you with basic trouble shooting..
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
heatman101
SOURCE: My Hampton Bay Model HB 50 Dehumidifier freezes
you are low on the freon charge you need to take to a service shop
were they can charge it.
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
