SOURCE: i need sky remote code for sharp tv model no lc-32sh7e
Hi there. I hope you will see this reply. I bought one of these TV's yesterday and I've got the code from my dad's website www.satcure.net
If your remote is Version 6 then you will be able to follow the help on the sky box under
Interactive
Customer service
Program Remote
Then follow the steps using code 1221
If you have a Revolution 8 remote then you will have an easier job but with a 3 digit code.
3 digit code is 253
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn
on the TV receiver
2. Press TV on the Sky Remote Control
3.
Hold down SELECT and the RED buttons together for approximately two
seconds, until the RED LED on the Sky remote blinks twice.
4.
Enter three digit code from list for the receiver (early versions now
flash twice).
5. Press select to enter code structure (the LED
will flash twice if a valid code has been entered).
6. Now press
the STDBY button and test other functions.
Hope this helps/works!
SOURCE: Can you give me the manufacturers PIN code for
There is no manufacturer's pin code. There are discrete remote control codes. If the problem is that the television is asking for a four digit code you have to go through the steps to clear all.
Press MENU to display the MENU screen, and then press to select "Setup."
Press ^/v to select "EZ Setup." "CH Setup," "Parental CTRL" or "Reset," and the Secret number Input screen displays.
Press and hold both CH ^ and VOL + on the TV simultaneously until the message appears on the screen.
If the problem you are having is that the television will not change inputs when you press the input button or something similar you will need to complete an Industry Initialization.
SOURCE: Sharp LC-19D1E-BK Instruction Manual
You can get the manual on the link below.
http://www.tradenet.sharp.co.uk/files/Consumer_Electronics/LCD_Television/LC19D1EBK/LC19D1EBK133.pdf
Good Luck
SOURCE: Need SHARP LCD TV LC-22L50M-BK Service Manual
hi go to this link to download the manual.thanks hope you rate my response.
http://www.sharp.com.my/aquos/operation_manual/lc22l50m_en.pdf
SOURCE: I have a sharp lc-32ad5e-bk.
I'd be very willing to bet you have a defective HDMI cord and the wire for the vertical sync has broken. Try a new cord and I bet you'll be golden.
59CSDAH
065
FOR 66FWF/54H CV-2133H(BK) 28JF73H 28LW92H 32LW92H DB5903H 51DT25H DV5161H DV5932H 66ES/03H DV51328 DV5107H 76SWS3H S6FWS3H DV5105H DV594TH DV5940H 59DS03H CV3730H, 28HW/50CH LC13E1E : [121].
