Without all emissionsystem, which conection on carbs shall be pluged and which shall I use?
SOURCE: Hi. This is a question
Standing in front of the car, #1 piston is the front one on your left. All odd number pistons are on this side and all even number pistons are on your right, front to back.
When you are lining this all up make sure your #1 piston is in the proper position to the crank. Check the position of your rotor button in the distributor. It should be lined up to #1, which is about 8:30 on a clock.Then turn the engine by hand past TDC and make sure the exhaust valve starts to open. The crankchaft turns twice to every one turn of the camshaft so it is possible for your timing to look right but not work. Hope this helps.
