SOURCE: flushmate 503 - loud squeaky scary noises
Have you tried the "800" number on the tank label or visited the Flushmate Web site?
Could be related to the plumbing or the Flushmate. Technical support should be able to help you pinpoint the cause and, if it's Flushmate-related and under warranty, provide a resolution.
SOURCE: I have a Sloan Flushmate
The only adjustment you can make is to crank your water pressure up...
But that probably will not solve your problem...
The best thing to do is to call the 800 number on the top of the tank and get technical assistance from them directly... they also will send you free parts if you need parts...
heatman101
SOURCE: I have a FlushMate series
Hi shirts,
That's right. One of the possible reason why you are encountering the problem that it's very slow to fill up is because of a clogged inlet screen. Here's how you can check it.
Checking Inlet Screen
Hope it helps.
Thank you for using Fixya.
SOURCE: I have a Sloan Flushmate, Model #M-101526-F3. The
Absolutely not! Because these tanks have air pressure inside them, and you can hurt yourself or somebody else. You need to get new one... take a look here Amazon com Sloan Flushmate tank. I hope this was helpful. cheers
You will need to remove the china holding tank from the toilet bowl by removing the nuts on the underside of the china tank.
After you have the tank off the bowl, remove the two plastic lock-nuts used to mount the Flushmate into the china tank and slide the Flushmate out of the china tank.
After you install the new tank-to-bowl bolts & washers, reverse the process to reinstall the Flushmate unit and remount the china tank.
