Heating & Cooling Logo
Jen Howell Posted on Jul 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Honeywell thermostat screen is not responding when I press buttons but the temp does change how do I fix this
Dennis Boxerman
Level 3:
  • Master 1,306 Answers
  • Posted on Jul 14, 2019
Dennis Boxerman
Master
Level 3:
Answers
1306
Questions
Helped
646288
Points
2787
It has been my experience that the screen is damaged. You will most likely have to replace the thermostat. I have seen where heavy scratches will cause this condition.
5 Related Answers
Anonymous
  • 579 Answers
  • Posted on Feb 10, 2008
SOURCE: honeywell round mercury thermostat - heat not coming on
If you tip the mercury switch so that it makes contact and the furnace doesn't start, it isn't the t-stat. Check the connections, then start checking the furnace.
In any case, ditch the mercury t-stat (recycle it properly) and get a new programmable one if at all posible. It will pay for itself many times over by turning your heat down in the middle of the night and back up by morning.
Anonymous
  • 518 Answers
  • Posted on Feb 22, 2008
SOURCE: honeywell thermostat
If you lost the manua, you can go to their site and download it.
Hard to help more without a model number. Sorry.
Geno
Anonymous
  • 6 Answers
  • Posted on Jun 25, 2009
SOURCE: Honeywell thermostat won't regulate temp properly
Is there a setting on your thermostat that makes the unit stay on for 10, 15, 20, 25 minutes after you reach set temp. You can change this setting by looking at your manual for the thermostat. Not sure if there is one for this thermostat but mine has one. Mine was running 15 min after set temp and making it cool down 2 degrees lower than set temp. Hope this helps.
Bill Long
  • 606 Answers
  • Posted on May 10, 2010
SOURCE: The thermostat worked correctly for months then
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need
Anonymous
  • Posted on Jan 13, 2013
SOURCE: screen frozen TH8320U1016 honeywell
I got mine to work! Mine is the th8110u1003 and although the screen seemed to display, it was completely unresponsive to touch. Long story short, there is a flat watch battery behind the screen. Get to that and remove it for 15 seconds and reassemble. It powered right back up!
2answers
How do I set Honeywell thermostat RTH300/RTH221 to one set, fixed temperature? Manual is a bit unclear
hold is for a fixed temp. run resumes a program. if hold is displayed on right side you are not running a program. the temp will change back to room temp NOT set point temp, this is normal but your setpoint temp did not change if hold is displayed.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
1helpful
How to change Honeywell TH3210d1004 thermostat from Celsius to farenheit
Press and hold up and down temp buttons together to enter settings menu. Then press up to option 14. Press down to change to option 0 (Fahrenheit). 1 is Celsius. Press up and down together to save and exit. Good Luck!!
1helpful
Change factory set date on thermostat
This is just general information for most thermostats. Press the set button until the date comes up. Press the up or down temp. buttons to where you want it. Press the run button to lock it in. I hope this helps.
1helpful
My Honeywell thermostat won't set the heat above 75 degrees
ok fist thing is to press and hold the middle lower button and the arrow up at the same time and hold until the screen changes to a number. keep hitting next until you see 75 appear then arrow up to the temp you want and press done. That easy!
3helpful
How do I set the temporary or permanent override feature on the Honeywell RTH2310B model thermostat?
To set the temporary override, press arrows up or down to desired temp. This will keep temperature
at temporary setting for 2 hours then return to programming. To permanent override press MODE button until schedule period number disappears (number inside little house on stat). Then adjust temp with arrows. Press the MODE button again to cancel override and return to programmable.
Thermostat does not read current settings or respond to commands.
HONEYWELL WEBSITE:
Go to honeywell.com
1helpful
3answers
Screen frozen TH8320U1016 honeywell
1helpful
2answers
Our TH8000 Series Programmable Thermostat keeps flashing "change filter" even after we changed it. The guide book does not show how to re-set so the flashing stops.
try holding the filter button in for three seconds, if that doesn't reset the timer try the filter button and the temp. up button at the same time for three seconds.
Top Honeywell Heating & Cooling Experts
Paul Carew
john h
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
