After clean, the magic chef chest frezer no linger frezen.
After clean, the magic chef chest frezer temprature no longer going down, no more frezen. But, I can still hear the machine running. The back of the chest frezer has not heat distribution any more.
I not 100% sure but believe this is the power light so it should remain on when the freezer calls for cooling and go off when satisfied. If the chest wont stay cold then it sounds like the stat is gone. If it is digital, there may be a power card issue but most chest freezers are run on a standard thermostat with the capillary running up into the base of the unit.
same as last post... I not 100% sure but believe this is the power light so it should remain on when the freezer calls for cooling and go off when satisfied. If the chest wont stay cold then it sounds like the stat is gone. If it is digital, there may be a power card issue but most chest freezers are run on a standard thermostat with the capillary running up into the base of the unit.
No check your settings. You may try to unplug it for about a minute and then restart. If that doesn't work, call the mfr. they should help since it is new.
Sounds like slow Freon leak. You might get an estimate over the phone before calling a technician, but I would think a 3-year old box is worth repairing. If the estimate is close to the replacement cost, that might not be the case.
5.5 Cu. Ft. Chest Freezer
Click to Enlarge
Lowest price:$179.00Description: Food
storage will be a snap with this roomy 5.5 cu. ft. chest freezer,
featuring up-front temperature control, storage basket and defrost water
drain.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
