Question about Radio Communications
My sub was paired when I got It then outta no where my sub started to get a blue flashing light please someone help me out
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: My phone shows me that my bluetooth is paired and
I had the same problem. I turned my phone off and then back on and that problem was solved.
Posted on Apr 15, 2009
Passkey to connect to samsung Freeform II.
When prompted for the password, enter 0000 and this will allow the headset to successfully pair with your phone.When pairing is successful, the indicator on your headset flashes blue. Your headset is now connected and ready to use.Hope you are satisfied with my solution.If you need further assistance please post me a reply.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
Jun 13, 2011 | Plantronics Hama Voyager 520 Bluetooth...
Hi I have a blueant z9i bluetooth and I can't seem to pair it to my phone I have a motorola defy could someone please help i've followed the instructions several times but nothing. Thank you Cherie
Have you tried to put your headset in pairing mode first? In order to do it, starting with it turned off, press and hold its multi-function button for some 6 seconds, until its indicator light turns solid blue, and, then, starts flashing. It is in pairing mode now. Then, bring your phone close to it, turn it on and go to 'Menu > Settings > Wireless & networks' and tick the 'Bluetooth' checkbox. Then, tap 'Bluetooth settings > Scan for devices'. After a little while, your headset should appear on the found devices list (if not, slide the screen down). Tap over it. They should pair with each automatically. Otherwise, if a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros).
Hope it works for you.
Anyway, please, let me know if I can help you any further.
Oh, if your headset's user guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Apr 27, 2011 | Motorola Mobility Defy Cell Phone
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
Phone can't discover the em227 blue touth need help please
You must put you headset in pairing mode, prior to trying to pair it with your phone. In order to do it, starting with it turned off, press and hold the power button for some 10 seconds, until the indicator light is alternately flashing in red and blue. It is in pairing mode now. Then, bring your phone close to it, and make its bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode (blue light flashing every few seconds). By the way, If its user guide happens to be missing, or, rather, you need further informations on how to pair it with your phone, feel free to download it from this location.
Regards,
Carlos
Jan 14, 2011 | Emerson EM227 Bluetooth Headset
SUDDENLY THS MORNING THE BLUE LIGHT ON AND THE RED LIGHT OFF ARE FLASHING ALTERNATELY IE WHEN AERIAL LOCATED TO ON POSITION THE ON LIGHT BLUE FLASHES ALTERNATE RED AND BLUE AND BLUE TOOTH NOT WORKING
I think your car kit has lost its pairing data. Blue and red lights flashing alternately means it is in pairing mode. On your phone (or the device it was paired with), delete the partnership with your car kit, and make it search for new devices again. After a little while, your car kit should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey, or passcode) is requested, enter '0000' (four zeros).
By the way, detailed instructions on how to pair it with your phone (illustrated with pictures) can be found on its user guide; In case yours happens to be missing, you'll still be able to find it here.
Hope you are able to sort your problems out soon.
Please, let me know if I can help you any further.
Regards, Carlos
Sep 03, 2010 | Blueant Supertooth Light Bluetooth Speaker...
Cannot pair my emerson (em227) headset to my ps3
turn the device off (red LED flashes) then hold the button for atleast 10 seconds until both BLUE and RED LED flash aternatively... not just blue, pairing code is 0000
Aug 25, 2009 | Samsung WEP200 Headset
It won't turn on. how do i fix it?
A steady blue light means it's in "pairing mode". Did you try to pair it with your phone during this time?
Aug 22, 2009 | Motorola Mobility H555 Bluetooth Headset
Headset does not flash red/blue so I can pair it with my phone
To get it into pairing mode (flashing red and blue) turn the headset off.  Hold the main button down until the light goes red and then off.  Then push and hold that same button and keep holding it even after the blue light comes on.  It will now go into pairing mode, flashing red and blue.  Set your cell phone to find it and it should work.
May 09, 2009 | Plantronics Discovery 925 Bluetooth...
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Radio Communications Logo
43 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
