Have you checked through the setup controls on the flat panel. I've seen a few that had the audio turned off by default. That is sometimes done because it generates static noice if there is no audio sourced coming through them.
The Acer H233H does not have a microphone built into the monitor. Thus you do not have to put tape over the microphone. It does have integrated down-ward firing speakers; the speaker jack is next to the power cord on the back of the monitor. Make sure to connect the included audio cord to the Lime Green audio (speaker) out jack on your computer. All of the jacks on the monitor point down.
If this monitor had a microphone and the blue 3.5 mm audio port, you could keep the microphone disabled simply by not connecting the cable between the monitor and the computer's microphone port.
I hope this helps. Web cameras often have microphones. Some laptops often have an integrated web camera; thus they have a microphone mounted on the bezel of the laptop. Blocking that microphone with tape might be useful. I'd block the camera too. For USB connected web cameras, simply unplug the data cable from the computer when you aren't using the camera to disable the microphone.
The monitor does not have sound passthru feature so the speakers would not be able to work that way. You can connect the speakers to the Roku box in the audio out jacks. You will need to get a cable from radio shack to make the connection.
There are a varity of HDMI cables, ensure that your version is supported also using the input touch "button" to change the input through VGA, DVI and HDMI.
you should be able to get sound when connected trough any of the three port. best port to use is hdmi or dvi connection. adjust your volume on your computer and make sure your audio drivers are updated.
The speakers are not supposed to plug into the monitor, they will plug into the speaker jack on the back of your computer (usually a green plug or it will have a picture of a speaker next to it)
Hope this helps
Good Luck!
