Delta & Single Handle Shower Faucet  Logo
Posted on Aug 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Leaking hot water from delta single handle facuet
Hot water is leaking from the tub faucet. I have removed the face plate,but can not figure out how to romve the handle
  • Anonymous May 11, 2010
    What brand of shower valve is it? Symmons, Delta, Moen etc? TY
jpintore
Level 2:
  • Expert 129 Answers
  • Posted on Sep 27, 2009
jpintore
Expert
Level 2:
Answers
129
Questions
Helped
89235
Points
219
When the handle is in the 12 oclock position you should see a set screw. Loosen and it should come right off.
Anonymous
Level 2:
Scholar:
  • Expert 44 Answers
  • Posted on Sep 26, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
44
Questions
0
Helped
24649
Points
108
I have to assume you've unscrewed the face plate, not removed it, because you can't do that without taking the handle off. Delta handle usually come off by unscrewing an allen (set) screw just under the handle itself. Sometimes these are covered by a plastic plug.
Occasionally, even after you've completely removed the set screw, the handle still won't come off. Wiggling and pulling for a few minutes will generally get it off. If not, then a hacksaw, new handle and new cartridge are the answer.
If the allen screw is stripped and that's why it won't ome off, see above.
Good Luck.
Leaky single lever bath tub faucet
Faucet is leaking due to seats bad.
1- Turn water off first and remove handle and remove collar that holds stem and remove it..
2- in valve there are seats that looks like caps they may be in valve body or the end of stem itself.
3- Remove them and the springs and replace them this will take care of the leaking problem.
Hi my delta single hanlde tub/shower facuet is leaking hot water bad
If its a ceramic cartridge type then replacing cartridge is called for, HOWEVER sometimes cheaper to replace complete tap.
If not ceramic then turn mains off and replace the washer inside.
My shower seems to run even after closing the shower to off position. the water is coming out hot?????? thankyou JOHn Vancouver
REPLACE THE CARTRIDGE. TURN OFF WATER, REMOVE HANDLE AND FACE PLATE. REMOVE TWO SCREWS UNDER PLATE. PULL OUT CARTRIDGE AND INSERT NEW. REASSEMBLE
1helpful
How to clean water marks on delta facuet
If you get 0000 steelwool, This will polish like new without scratching.
Delta T13090 faucet shower head working at the same time.
The only possible explaination is that the water is finding it easier to go up than down. Water is lazy, just like me. ;)
Use an allen key to remove the tub spout. It's underneath and awkward. Once the allen key is loose, the spout just slides off. Try running the water. This may solve your problem and all you'll need is a new tub spout. If not.....
Turn the water off to the house.
Use an allen key to remove the handle.
Use a phillips to remove the trim plate (2 screws). Cut the silicone around the trim if it's there (which, in a proper installation it shouldn't be, but...)
Unscrew the nut (usually chrome) holding the cartridge into the brass body of the valve. The cartridge pulls straight out. Check for restriction in the ports of the cartridge itself. Check for restriction in the line going down to the tub spout. If you can't find anything, replace the cartridge.
Reassemble & Enjoy!
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Single handle facuet for shower/tub leaks hot water
change the cartridge it is bad,it has rubber gaskets on the outside of the cartridge it is worn,just replace it and it should work,it may also be trash in the way.take out and shake,if this does not work replace with new cartridge.
Tub faucet
You will need to turn of the water and remove the handle, then remove the large brass or chrome ring behind the center sleave that is behind the handle. now that ring is what holds the cartridge in the valve body, you will need to remove the cartridge the rubber seats and springs will both need to be changed ,you can buy a rebuild kit for this facuet, it has everything you need even the o rings you will find in there . Hope Ive Solved your problem! Thanks
Top Delta Home Experts
john h
Paul Carew
Paul Bade
Are you a Delta Home Expert? Answer questions, earn points and help others
