My ice maker fills the ice cube tray with water, when the water turns to ice cubes the ice tray turns over but the ice does not fall out, then the water fills up the tray again as if the tray was empty only to over flow the tray and gets water over everything.
Is it the bottom sliding door freezer? I found if not balanced properly, the freezer door doesn't always close entirely. Therefore the ice begins to melt once made. As the door is slide open and closed, sometimes all the way other times only partially. Therefore it thaws and refreezes over an over making the block.
half filled ice trays
ice tray half filled
Ice want fall out of the tray
