SOURCE: Can set at 1/2, 1, or 1 1/2 gallon and get only 2
There is a set lock on the timer board, if you've tried that already then check solenoid valve, make sure it works, if yes then problem is timer board.
SOURCE: MAYTAG SAV2555AWW TOP LOADER. SUDS
Sounds like the house drain can't handle the output from the washer's pump. Try to use the proper amount of detergent to reduce suds level. You might have to increase the size of the hose drain spout with duct tape so that it fits into the house drain tightly. Hope this helps!
SOURCE: Does my kenmore washer model
it is not advisable to put actual bleach inside the washingmachine[or you could use a proprietary washing machine cleaner. Thepurpose of a maintenance wash is to remove any mold, bacteria, old detergentresidue and gunge. If using white vinegar, it is important to allow the washingmachine to fill for about 30 seconds before adding the vinegar, as the firstbit of water goes into the sump.
SOURCE: How do I make the conversion from gallons of liquid to 1 liter ?
A simple Google search can tell you that answer:
1 gallon = 3.78541 litres
or,
1 litre = 0.264172 gallons!
SOURCE: how many gallons are contained in a 1 liter bottle of water ?
There are .26417 US gallons to 1 Liter
OR
0.2199 Imperial Gallons to 1 Liter
