Question about Samsung Audio Players & Recorders
How can I fix my Samsung home theatre model number: HT-330k
SOURCE:
SOURCE: rear check message on HT-TXQ120 samsung home theatre
Looks like it is to do with the rear wireless speaker. Now, my problem is over. Its gone. I first turned the reciever on and then turned on the rear speaker wirel less on. No rear chk in problem now. Hope this helps. R.
Posted on Apr 14, 2009
John-INSG
  • 312 Answers
SOURCE: Insignia Remote Code Needed for Samsung HT-X40
Many remote control codes can be found at InsigniaProducts.com. Search for your Insignia product model number and click on the Support tab.
Posted on Feb 05, 2010
SOURCE: SAMSUNG HOME THEATRE HT-Z310 will not play dvd's
if its less than 1 year old get it fixed by samsung. if older, buy a new dvd drive http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=390140887510
Posted on Feb 08, 2010
jdvillanueva
  • 2098 Answers
SOURCE: My Samsung HT-WZ410 home theatre
I've advice you to check your exhaust fan if working properly.
The processor shuts down the unit because it sense that you have a problem on the fan.
This is happen to avoid further damaged to your output I.C. which is quite expensive.
If the fan is not working then try to clean it, sometimes it is full of dust that caused to stop from functioning. If you confirmed that the fan is already defective then replaced it with a new one.
After replacing and the symptom is still there then I've advice you to look for a qualified technician because there might be sometime wrong on the board (faulty parts).
Pls rate my help.
Thanks for using fixya...
Posted on Jan 15, 2011
Wolfman304
  • 720 Answers
SOURCE: id like to know how
Hiya,
Try this procedure:
1) Unplug player from power socket (for 1min)
2) Connect plug to power socket
3) Using the remote, press POWER button to turn unit on.
4) Press DVD button to enter dvd-mode
5) Press the following remote buttons, in this sequence:
ENTER, 8, 4, 2, 6, 9, ENTER
If done correctly, your dvd should go into Standby mode.
6) Press POWER button to turn unit on.
Cheers,
"If this works, please rate this solution with thumbs up"
Posted on Jun 16, 2011
Samsung home theatre HT-X30,
The DVD player may have failed.
Dec 19, 2013 | Audio Players & Recorders
Is it possible to connect this model of wireless headphones to a Samsung HT-C5900 Home theatre system?
So long as there's a regular 3.5mm headphone jack on the Samsung home theatre system, then yes they should work. If not, I would try hooking them up to your HDTV directly.
Mar 02, 2011 | Philips SHD8900 Wireless Headphones
Dec 27, 2009 | Samsung HT-X40 System
SAMSUNG HOME THEATRE HT-Z310 will not play dvd's everything else works ok just comes up disk error on all dvds
Nov 22, 2009 | Samsung HT-Z310T Theater System
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
Connect the PS3 with HDMI to the Home theatre.
Connect the TV digital optical out put to the optical input cable of HT-BD2R provide your tv has a optical digital out put
You have the option of channeling the out put through either optical or HDMI in PS3.Go to the set up and set the audio out put to HDMI
Nov 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Rear check message on HT-TXQ120 samsung home theatre
Nov 19, 2008 | Samsung HT-TXQ120 Home Theater System...
20 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
