Televison & Video Logo
A
Anonymous Posted on Jul 09, 2019
Buy 100% Undetectable Counterfeit Money Shiiping within the US and CANADA...24 HRS Shipping to Europe... 72 hrs Shipping to Asia.and Africa..5 days
5 Related Answers
walkerpkw
Patrick Walker
  • Posted on Nov 05, 2008
SOURCE: We own a RF267AARS/XXA refrigerator.
You'll have to read my in depth review on Epinions.com for answers. Sounds like you bought the updated version that over corrects the "too much" ice which jams the mechanism to where it breaks the unit. This is my second friggen Samsung as my 1st 4 door quatro was replaced under their lemon law. Spending $2500 I thought I was buying quaility, instead I bought greif. I'm still working with Best Buy to get Samsung to fix the icemaker with it's current problem which sounds like yours. Go to the Epinions website and look me up, my username is "walkerpkw" My review was posted last year. Read both my horrifying Samsung reviews. Something is very wrong with their engineering department. You'll find my email address on my profile page. I'd be happy to inform you if the get this fixed. I'm told it's the fridges computer board and they're redisigning another?
Anonymous
  • 58 Answers
  • Posted on Jun 22, 2009
SOURCE: My rado original automatic dive watch that I
Yes I had this issue, it was fixed under warranty
Anonymous
  • 83 Answers
  • Posted on Jul 10, 2009
SOURCE: not sure how long to run pump
First, RECYCLE is a position that allows water to continue to circulate through the system, BYPASSING the filter. If there is a problem with the system, like an air intrusion/leak, by putting the filter in RECYCLE you can determine if the problem is in the filter, or another part, of your system.
As for how long to run the pump, it can be ran 24 hours a day. Normally, the average run time is 8 to 10 hours a day. Most city codes require that pool water is "turned over" one time daily. This means that all of the water in the pool is ran through the filter at least once a day. Usually, 8 to 10 hours will give you that requirement.
Hope this helps!
Anonymous
  • 185 Answers
  • Posted on Mar 22, 2010
SOURCE: Ice maker only produces 30 cubes per day (24 hrs) since new.
You probably need more water pressure going to the frig. check that first.!!
Anonymous
  • 1188 Answers
  • Posted on Jul 02, 2010
SOURCE: Unable to charge. it still says charging
You should return the product. This is relatively common, it needs a new battery. The battery will not take a charge. Here's the thing, batteries for cordless phones are a fortune. You should either return it or if you can't probably just buy a whole knew one.
EJ
Delonghi problems
Mains voltage in Australia is 230V 50Hz. Travellers from most nations in Asia, Africa and Europe should have appliances that work on the same mains voltage as Australia - therefore you will not need a voltage converter. Notable exceptions to this are Japan, USA and Canada which uses 100/120V 50/60Hz.
If your country does not use appliances within the 230V 50Hz mains voltage range, you will need to purchase a voltage converter. This will transform the voltage from the power outlet into one your appliance can use. You will also need a power adapter.
How long it will take to receive my tv repair kit?
Usually tracking information is emailed and within 24 hrs tracking should be updated in most cases of the item shipping.
Is the Samsung Ln46a530 dual voltage ie (110 America - 240 Europe)
The tv power supply board is not the problems,that can add a transformer to solved it easily.The problems are US and Europe uses a difference tv signal frequencies.The US,Canada and Mexico are using a NTSC signal frequencies.Europe,Asia,Middle East and Africa are using PAL signal frequencies.U must have a tv that call REGIONS free tv to work in Europe and US same time.If u just have a standard LCD or a Plasma HD tv buy it in the US for example will not work in Europe
Does the protron pltv 32cm (model name LT32c1m1 - 2005) works in Brazil? do I need to buy any accessors to make it works?
Where did u bought this tv?Buy it from Asia,Europe,Austria,Africa,middle East?All these countries places are using the same frequencies signal which is PAL,and used 230V.Buy it from USA,Mexico,Canada?All these contries places are using the same frequencies signal which is NTSC,and used 120V.
Multi-region code for a bush BTVD31217S2
Seven regions (also called locales or zones) have been defined, and each one is assigned a number. Players and discs are often identified by their region number superimposed on a world globe. If a disc plays in more than one region it will have more than one number on the globe.
1: U.S., Canada, U.S. Territories
2: Japan, Europe, South Africa, and Middle East (including Egypt)
3: Southeast Asia and East Asia (including Hong Kong)
4: Australia, New Zealand, Pacific Islands, Central America, Mexico, South America, and the Caribbean
5: Eastern Europe (Former Soviet Union), Indian subcontinent, Africa, North Korea, and Mongolia
6: China
7: Reserved
8: Special international venues (airplanes, cruise ships, etc.)
Hope this helps
How do i know who much time it takes to defrost a whole chicken?
Defrosting times for the Refrigerator Method 5 lbs -
7 lbs -
10 lbs -
12 lbs -
15 lbs -
24 hours (1 day)
34 hours (1 day 10 hrs)
48 hours (2 days)
58 hours (2 days 10 hrs)
72 hours (3 days)
1helpful
Does this model support PAL color system? I misplaced my user manual and i am unable to change settings.
Where did u bought this LCD tv,if u buy it in the US,Mexico or Canada no it only work with a NTSC signal frequencies.If buy in Europe,Asia,Australia,Middle East or Africa.Yes,it will work with PAL signal frequencies.
4helpful
3answers
What does RC 1 mean
RC means REGION CODE - Depending on the numbering, it means that your DVD will only play in countries designated by the code.
Example
RC 1 means Region Code 1...... This disc will play in dvd players in Canada, United States, U.S Territories , Bermuda.
RC 2 = Western Europe, incl. United Kingdom, and Central Europe; Western Asia; including Iran, Israel and Turkey, Egypt; Japan, South Africa, Swaziland, Lesotho; French overseas territories
RC 3 = Southeast Asia; South Korea; Taiwan; Hong Kong; Macau
RC 4 = Mexico, Central and South America; Caribbean; Australia; New Zealand; Oceania;
RC 5 = Ukraine, Belarus, Russia, Continent of Africa, excluding Egypt, South Africa, Swaziland, and Lesotho; Central and South Asia, Mongolia, North Korea.
RC 6 = People's Republic of China, Hong Kong
RC 7 = Reserved for future use (found in use on protected screener copies of MPAA-related DVDs and "media copies" of pre-releases in Asia)
RC 8 = International venues such as aircraft, cruise ships, etc.[1]
RC ALL means all 8 flags are set and can play on ANY player
0 or no region means no flag is set can be played anywhere or flags 1-6.
I hope this helps.
We have some dvds from england that we car'nt play.It is saying we need a code. just wondering how to get the code. thanks
Copy and past this into note pad fore better view,
Code Region
0 Informal term meaning "worldwide". Region 0 is not an official setting; discs that bear the region 0 symbol either have no flag set or have region 1–6 flags set.
1 Canada, United States; U.S. territories; Bermuda
2 Western Europe, incl. United Kingdom, and Central Europe; Western Asia; including Iran, Israel and Turkey, Egypt; Japan, South Africa, Swaziland, Lesotho; French overseas territories
3 Southeast Asia; South Korea; Taiwan; Hong Kong; Macau
4 Mexico, Central and South America; Caribbean; Australia; New Zealand; Oceania;
5 Ukraine, Belarus, Russia, Continent of Africa, excluding Egypt, South Africa, Swaziland, and Lesotho; Central and South Asia, Mongolia, North Korea.
6 People's Republic of China, Hong Kong
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
