Try this site if it will help: https://www.manualagent.com/realistic/pro-50/users-manual
SOURCE: Radio shack Pro-433
Look at www.radioreference.com This is the most complete scanner site on the web. Just register and then search the forums for what you need.
SOURCE: Radio Shack Pro-2043 scanner
Hi, According to this site, the manual is not available. But this link has all the info available on separate pages to be printed off. All you have to do is copy and paste and print,, can't get too much easier.
http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=20-415&
Name=Radio%20Scanners&Reuse=N
I hope this helps you out,, Mechanic
SOURCE: Owner's/Instruction Manual
Hi SDGirl - This is a slightly older model and there's not much out there. You won't find one at Tandy or Radio Shack Sites. I'll give you a link where you can find it ( sort of) in sections. I believe it will tell you everything you need to know. If I were you I'd probably copy and paste each section into Word or something so you'll have it all in one place. This is about the best out there. If this solves your problem PLEASE rate this as fixed. ( I looked alot for you). If you need more help just add a comment and I'll be happy to assist you further. If this doesn't solve your problem let me know before you rate and I'll try for something better. Thanks.
http://support.radioshack.com/support_electronics/36547.htm
Jeff
