If the red light is blinking on your Konica Bizhub 423, it usually indicates an error or issue with the printer. Here are a few things you can try to resolve the issue:
Check the display panel: The display panel on the printer should show an error message or code indicating what the issue is. Check the manual or contact Konica Minolta support to find out what the error code means.
Restart the printer: Try turning off the printer, unplugging it from the power source, waiting for a minute or so, and then plugging it back in and turning it on.
Check the toner: If the toner is low or empty, the printer may not function properly. Check the toner levels and replace the toner cartridge if necessary.
Check for paper jams: Paper jams can cause the printer to stop working. Check the printer for any stuck paper and remove it carefully.
If none of the above steps work, you may need to contact Konica Minolta support for further assistance.
C-0070 is the toner bottle, remove it, power off the machine, then with the bottle out turn the machine on, let it go thought its routine when it ask for toner install it PROPERLY if the knub on the bottle dented damage in anyway replace do not use the damaged bottle. the C0F32 is the toner is not properly mixing in the the developer because it is not getting any toner see above, Might need to replace the developer also.
Check for a code 42 , indicating that your printer has a cartridge region mismatch error. Turn off the printer. Leave it off for at least 20 seconds. Then turn the printer back on and try printing again. Confirm a cartridge mismatch. If the error code continues to appear, then check the printer and toner cartridge settings to identify which is not matching Determine if you need to return the toner cartridge for and get a replacement cartridge that matches your printer's geographic region.
Dear Make sure the toner you purchased is genuine. Also make sure that the printer region and the toner region it matches( the samsung manufacture the detection chips of the toner and printer region wise)Contact Samsung call center and ask them for how to clear the memory and select the correct country of your location. If you have refilled the toner it may not work properly. you need to contact refiller to get compatible chip.
This may be a toner cartridge region mismatch. Replace the toner cartridge that matches the region of the printer. Or you can also try restoring the printer to factory defaults by following the steps below:
