Hi Ramon, as you say, the protection circuit is working, you would have a problem in the power supply or in the audio outputs of speakers
I suggest you disconnect, all the speakers and test if the fault continues, if it does not continue, connect the speakers one by one and test until the possible fault is detected
If you disconnect and stay the same, I suggest you look for a specialized technical service
If you have knowledge and technical expertise, I give you the link to download the service manual of your Pioneer
I hope you can solve the problem
Regards Franco Dosil
Hola Ram?n, por lo que comentas, esta trabajando el circuito de protecci?n, tendr?as un problema en la fuente de alimentaci?n o en las salidas de audio de parlantes
Te sugiero desconectar, todos los parlantes y probar si continua la falla, si no sigue, conecta de a uno los parlantes y prueba hasta detectar la posible falla
Si desconectas y sigue igual, te sugiero busque un servicio t?cnico especializado
Si tienes conocimientos y pericia t?cnica, te paso el link para que descargues el manual de servicio de tu Pioneer
Espero puedas resolver el problema
Saludos Franco Dosil
https://www.manualslib.com/manual/1259236/Pioneer-Vsx-523-K.html
https://elektrotanya.com/pioneer_vsx-523-k_vsx-533_rrv4418_sm.pdf/download.html
SOURCE: Remote code for Pioneer VSX-50 A/V receiver.
Here are the codes for your receiver:
Pioneer 31023, 30014, 30244, 30150, 30630, 30080,
30531, 31384
Here is a link to your manual:
http://www.directtv-advisor.com/support-...
SOURCE: Bose 901 connection to Pioneer VSX-917v Receiver
any pre-out should work. i believe the bose have a rca jack connector for attaching to the receiver. look at the new receiver connection diagram. any output that is rca designed for use by a recording device will send a signal that the 901's can see.
always check the manual on both before connecting for any precautions.
good luck
mark
SOURCE: pioneer vsx-d511 amp error
I've had the same problem for over a month and have yet to find the time to get to it. However, I there may be a fuse on the circuit board that needs to be replace. That's just my guess.
Hope it's the solution.
SOURCE: Pioneer VSX 915 powe off
Had a power surge last night and got the same problem. Unit wont power on and has a blinking blue light on standby button. I found the solution from the service manual for a similar model.
Hold down ENTER and ADVANCED SURROUND buttons.
This resets the DC overvoltage sensor and bingo the unit comes back to life again.
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-D510-Receivers-manual/id/385ci969/t/2/
or photos...
http://www.avland.co.uk/pioneer/vsxd510/
http://www.avland.co.uk/pioneer/vsxd510/rear.jpg
http://cgi.ebay.ie/PIONEER-DOLBY-DIGITAL-5-1-DTS-AMPLIFIER-RECEIVER-REMOTE-/110611664116
