Question about Locks & Locksmithing
I NEED TO OPEN MY SAFE. THE BATTERY IS FLAT AND THE KEY IS NOT WORKING
  • 23 Answers
I have little respect for safes that use batteries ever since i heard many can be "bumped" to open them. bumping is little more than one hand on handle to open safe and one hand holding a mallet (hard rubber to protect finish) then hit safe from different angles while gently trying to turn handle to open position. it's same principle as opening a pin tumbler with an oscillating device (VI- BRAY - TOR). takes a soft touch and a little patience until you get feel of technique then will be easy in just a few seconds.... Telling us the model/manufacture might be a good idea too
Posted on Jul 13, 2019
SOURCE:
SOURCE: BATTERIES FLAT CANNOT OPEN MICROMARK SAFE WITH KEY
http://www.rotteneggs.com/r3/show/se/198433.html
:D x
Posted on Jun 02, 2009
  • 510 Answers
SOURCE: battery flat, cannot open doors key not working on
If your key will not manualy open door
Try it in boot lock,it might activate central locking
Posted on Feb 24, 2010
  • 313 Answers
SOURCE: battery flat lost keys how do i open safe
Most of these safes come with a default setting. Try entering 0000.
otherwise you will need to locate the serial number and contact the manufacturer.
Posted on Jul 25, 2010
heatman101
  • 43501 Answers
SOURCE: Battery is flat and the
I think that this is what you are looking for...
How to open electronic safe
http://www.ehow.com/how_4480775_open-electronic-safe.html
heatman101
Posted on Feb 23, 2011
jyackle5
  • 8197 Answers
SOURCE: I have an ES20 safe,
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
Posted on Apr 09, 2011
Safemark hotel safe code to change the battery
You open it with the code to open the safe. The battery is in the rear of the door. If your battery is flat, you use the key. The key hole is usually hidden behind an escutcheon plate or badge.
There is no magical master code to open this type of safe.
Videos and a link to Safemark
safemark hotel safe Google Search
This shows the key location
085 Safemark hotel safe not bad
safemark hotel safe change battery Google Search
Sep 05, 2018 | The Home Security
Need instructions to open Sandleford Digital Safe N15115 RX2009 106 485.
Hi Leanne
Try this is contacting them direct.
Sandleford Digital Safe Instructions
www.sandleford.com.au/Content/images/.../sandleford/DS200_250_300_500_230.pd...
6. Door Handle. 7. Battery Compartment. 8. Locking Bolts. 9. Reset Button. 1. 2. 3. 4. 5. 6. 7. 8. 9. 0. #. *. 3. 7. 8. 9. 21. 4. 5. 6. DIGITAL SAFE. INSTRUCTIONS ...
How to reset code on an electronic safe - YouTube
? 1:04
https://www.youtube.com/watch?v=_tqTp57YfCw May 11, 2013 - Uploaded by donutdaveyboy
How to open a digital safe without any tools or keys IN 2 SECONDS! - Duration: 2:19. Firealarm102 131,330 ...
How to open digital safe when battery is flat and key not working ...
? 1:15
https://www.youtube.com/watch?v=aqC9V7SDKdQ Nov 9, 2012 - Uploaded by khthhonl
How to open a digital safe when the battery is flat and the key does not work? This method takes less than a ...
Sandleford Digital Safe N15115 Google Search
Apr 24, 2017 | Locks & Locksmithing
Battery is removed and the keys are inside
Is it a safe with an electronic lock? The safe usually comes with a key that you should keep outside the safe not in it exactly for this flat battery scenario that you're in. The battery box for your electric lock is usually on the inside of the safe so you need the key to open the lock. You can force it open, check this video https://www.youtube.com/watch?v=aqC9V7SDKdQ
Jan 13, 2015 | Locks & Locksmithing
I MISTAKENLY LOCKED UP MY SAFE KEY INSIDE THE LOCK AND THE BATTERY IS TOTALLY DEAD ,PLEASE I NEED HELP
you would need to hot wire the batteries for the code to work but if the batteries have gone flat then it needs to be re-programmed again ,only one soloution here and thats to open it with a radial cutter
Nov 20, 2011 | Locks & Locksmithing
Digital safe. combination isint working. key was lost years ago. urgent that get open grocery money is inside.
I assume you have been able to open it with the key code up till now?
Its possible the batteries are flat. Most digital safes only have access to the batteries once it is open.
If you can access the batteries from outside try replacing them.
If the safe is only a cheap model use an angle grinder to cut it open, or take it a locksmith.
Good luck,
Steve
Oct 12, 2010 | Computers & Internet
Can not open nu tool sf 10 electronic digital safe
If the batteries are flat you will need a key to open your safe, the keyhole is usually under a plastic cover on the front of the door.
If the batteries were getting low a light should have warned you.
Hope this helps.
Mar 05, 2009 | Computers & Internet
Locks & Locksmithing Logo
23 people viewed this question
Top Locks & Locksmithing Experts
john h
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
