I bought tom tom gps one xl, only use once, still with in one year
warranty. I bought new map from website, but can not install.
I paid $ 470, still can not use
If the software crashed whilst updating, you will find that if you try to restore from a complete backup when you switch on next time it will either say you cant use the map or will just freeze, fix re format both the internal memory and the memory card, then find where tom tom home had stored the files, then using windows copy the contents from the 2 folders back into the relitive internal and external card, you will then find that you will get the mesage that you cant use the map, this is because tom tom home doesent always put the map data into the correct folder, to fix this find the licence data and the map data that has been stored on the sd card instead of the internal memory and copy it into the internal memory, before switching off press the reset button, when you switch on you should find that you have a working tom tom
