Question about Roland Spd-S Sampling Percussion Pad System
Memory card cant be detected by spd-s aftr downloading ver 1.20
My memory card cant be detected by spd-s aftr downloading ver 1.20.
the update proggres goes fine, but i cannot load my (MC) on my SPD-S. "checking card- unformated!"
when im tryin to format it, the dispaly says "card ejected"
can anyone fix my prob?
thx
3 Suggested Answers
SOURCE:
SOURCE: Roland SPD-S Flash card error
The card I have always been using is now also suddenly giving this message. I found an old SanDisk 16MB and a 1GB SanDisk that works perfectly in my Boss 864 and they also give the same message. Trying to go into formatting brings the message "no card!"
Posted on Aug 26, 2008
  • 8 Answers
SOURCE: Bought used Roland SPD-11 with
Manuals are here in PDF:
ftp://ftp.roland.co.uk/productsupport/Manuals/
Posted on Dec 31, 2008
Will 1gb ddr2 800mhz ram support intel102ggc2
The board has two 240-pin DIMM sockets and supports the following memory features:
  • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts
  • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported.
  • 2 GB maximum total system memory
  • Minimum total system memory: 128 MB
  • Non-ECC DIMMs
  • Serial Presence Detect
  • DDR2 533 or DDR2 400 SDRAM DIMMs
Note
To be fully compliant with all applicable DDR SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance. If non-SPD memory is installed, the BIOS will attempt to correctly configure the memory settings, but performance and reliability may be impacted or the DIMMs may not function under the determined frequency.
May 27, 2010 | Intel D102GGC2 Motherboard
Mother board software loading error,SPD missing
Serial presence detect (SPD) refers to a standardized way to automatically access information about a computer memory module. Earlier 72-pin SIMMs included 5 pins which provided 5 bits of parallel presence detect (PPD) data, but the 168-pin DIMM standard changed to a serial presence detect to encode much more information
Apr 20, 2010 | Gateway (12210140-90) Motherboard
One shoe won't snap into spd pedal
SPD hold on to cleats with a spring loaded action. This is normally adjusted with an allen key. Check that this is not screwed in so tight that action is locked up. If you don't have adjustment instructions go to shimano.com and download. You should be able to check for movement by pushing against spring clip with screwdriver (saves the fingers but mind it doesn't slip). If no movement also check for foreign body in pivot of clip. If all OK check for position of cleat in shoe. Make sure mount position is same as other shoe.
Dec 06, 2009 | Shimano M520 Spd Pedals
How to reset my roland spd-s
You can reset Roland SPD-S by using Roland SPD-S utility CD supplied with product.
If you can't locate (or lost) the CD that is included with the SPD-S which contains the factory data, you can download the file here:
http://www.rolandus.com/products/pro...37&ParentId=61
Click the downloads tab and select the "SPD-S Factory Restore Data" (PC or Mac) link.
I think it helps.
If you have any query regarding this issue leae a feedback we were happy to assist you.
Have a Nice Day!
Oct 14, 2009 | Roland Spd-S Sampling Percussion Pad...
SPD-S.....Internal Memory Full
if you have the samples in .WAV then you will have to IMPORT them, because SPD-S can only play .SPD files (import will convert from WAV to SPD).If you have produced your samples with your SPD-S (via mic or line-in or PhraseMaker) then they are already in .SPD-format and can be assigned without importing.
In this case you just have to assign a sample to a pad, by pressing CARD ("card"=lit) you can assign samples from your CF-card to a pad.
Dec 31, 2008 | Roland Spd-S Sampling Percussion Pad...
Sl-75frv memorys
Dear Sir,
You can install upto 3 GB RAM. i.e. 1GB PC3200 DIMM RAM in each slot.
Please go to BIOS settings & load the defaults. / check following. BIOS settings.
DIMM clock & timing is auto/ detected by SPD (Serial Presence Detect)
Possibly the 1GB RAM you are trying to install does not have SPD / is faulty. Try with a new / working 1 GB RAM.
Hope this helps you friend...
Jul 10, 2008 | Soltek SL-75FRV Motherboard
Upgrading RAM
Yes that should not be a problem as DDR is backward compatible with the slower speeds so the faster RAM, will just slow down to match. These are the only conditions listed so as long as the stick you have doesn't fall under this criteria you should be good.
he D845GLVA board provide the following memory features:
  • 2.5 V (only) 184-pin DDR SDRAM DIMMs with gold-plated contacts
  • Unbuffered single-sided or double-sided DIMMs
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • DDR266/200 MHz SDRAM DIMMs only
  • Serial Presence Detect (SPD)
CAUTION:
Do not use ECC DIMMs with this board. Using ECC DIMMs could damage the board.
Integrator's Notes:
  • Registered DIMMs are not supported.
  • Double-sided x16 DIMMs are not supported.
  • If a full-length PCI add-in card is installed in PCI bus connector 1 (the PCI bus connector closest to the processor), remove the add-in card before installing or upgrading memory to avoid interference with the memory retention mechanism.
  • This board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated (currently validated up to 1.0 GB) on this board.
Note:
Enjoy the increase in RAM,
Lee
Jun 14, 2008 | Intel Desktop Board D845GLVA...
Probblen in Additinol RAM
Hi Raj_jp, the Intel D845GLLY board must have SPD memory to function correctly in the system. The memory you added (512MB) must not support SPD. To help you understand what SPD is, you can click on this link which explains what SPD is.
http://searchcio-midmarket.techtarget.com/sDefinition/0,,sid183_gci533524,00.html#
The memory sold in this next link will function in you're Intel motherboard. http://www.memory-up.com/Memory/IntelD12696.html
So will the memory in this next link.
http://www.memorystock.com/memory/IntelD845GLLY.html
If you bought the 256MB memory recently, you should be able to return it & have it exchanged. The link above also lists the part number for the memory.
Good Luck!
Remember you're Intel motherboard uses you're system memory to run the onboard video card. The total amount of memory the video card uses can be adjusted higher or lower. You can adjust this in the bios. Go to Advanced Menu. Page 40 in the Intel user manual. You can download you're manual at this link.
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-008853.htm
Mike
Jun 02, 2008 | Intel D845GLLY Motherboard
File import
Try IMPORT instead of just trying to load them on your SPD-S.
The SPD-S uses some kind of its own file-format.
Regards
May 18, 2008 | Roland Spd-S Sampling Percussion Pad...
May 13, 2008 | Roland Spd-S Sampling Percussion Pad...
Roland Spd-S Sampling Percussion Pad System Logo
265 people viewed this question
Top Roland Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
