Amazon com Charm sonic 2Pack 4 9Feet 1 5Meters USB Charger Cable for Apple...
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections .A thumbs up would be greatly appreciated if this answer is helpful to you.
Likely the amp has gotten too warm, and the PA (Power Amplifier) is blown out of it, or it is being bridged incorrectly. These amps suffer from generating lots of heat.
Not really worth repairing, my opinion. Can be found on 'net for pretty cheap.
If the fuses only blow after the remote voltage is applied, the output transistors are likely shorted.
According to the owner's manual, the amp should have two 20 amp fuses.
I hooked it up the same way my other amp was connected ground first then remote and then b+.I am absolutely sure of the wiring.I replaced both capacitors cleaned the circuit board new fuse and the saame thing happens.I guess i was hoping for a common problem so that i wouldnt have too take the components out to test ????
Sounds like the +12 volts is being connected to the -12 (ground), i.e., hooked up backwards -- are you sure the +12 is being connected to the correct wire/terminal? What is the source for the +12 volts you are connecting to it? Charlie
Must not have the caps hooked up correctly. How is everything wired up? Try the amp without the caps. See what happens.
