Nope. No external jacks for video and audio. You can use the antenna connection with the dvd /vcr player by connecting the antenna out on the player with a suitable length of coaxial cable with F connectors on both ends. Then you would locate the channel 3/4 switch on the player and choose either one. On the TV you would put the same channel on the TV tuner that matches the player channel and you will see the picture.
You can use a normal set top box, plugged into the AV inputs on the combo, you could even use a seperate VCR for this, as long as it's recieving the signal you want to record.
I would need your exact model # to get very specific, but in general:
The "External tuner" will need to come from your TV or a cable/sat box, generally. If your TV has a Video OUT or a Monitor OUT (most television don't), you can hook a yellow AV/RCA video cable from the TV to the Magnavox. You will also need to hook a red/white audio cable from the Audio OUT of your TV to the Magnavox.
Your TV probably doesn't have a Video OUT, so you will need to buy a box. A digital cable box for your cable service would be the best investment. Alternatively, if you can find a digital-to-analog converter box (but these are iffy). Once you have one of these box types, you will need to hook a red, white, and yellow AV/RCA cable from the video/audio OUT of the box to an available video/audio in on your television.
Once your connections are correct, the general rule with tuner-less recorders is: If you can see the channel that you want to record on the television screen, then you will be able to record it.
One final note about Feb 17, 2009: Thanks to Congress, the digital transition date was moved to June 12, 2009 - many areas have already switched, but there is at least a chance that you are in an area that hasn't switched yet.
Let me know the exact model # of your television, and I can tell you if it has a video/monitor out - or, let me know what type of box you decide to buy.
If the original TV doesn't have audio/video inputs, you'll need a DVD/VCR player that has a built-in RF modulator. A RF modulator takes the audio & video and modulates a RF carrier to one of the channels that your TV can receive. In the U.S., this is usually channel 3 or 4. If the DVD/VCR player has a built-in tuner, connect your cable to the RF input of the DVD/VCR player and the RF Output of the DVD/VCR player to the cable input of the TV. This way, you can receive your cable channels through the DVD/VCR player and watch movies as well. If your DVD/VCR player does not have a built-in tuner, you can put a RF switch inline that will allow your TV to either receive the cable signal or signal from the DVD/VCR player.
I was able to connect to my cable box. I used RCA (yellow, red, white) cabling. I connected the Video Out on the cable box to the Video In on the DVD/VC (to the DVD VCR cabling section). I then from same section used the Video Out using RCA Cabling to the the Video In connectors on my Phillips LCD TV. That left only to connect the TV to the cable box using regular TV coax cable. Everything works, although I am going nuts trying to dub from VCR to DVD-R or +R discs.
ok you hook up dvd to what input... you hooked up sat on what =input.. do you have old vcr around.. try hooking cable to vcr and in a sense use its tuner to tune with . this will tell you if your tv has a bad tuner... just hook the vcr to the same input the sat or dvd player is on
